STM32L496xx | Boots issues :( Topic is solved
Sleuek
Post by Sleuek »
Hi everyone!
I'm really new in ChibiOS devlopment.
1. A boot not interrupted result in receiving a SIGTRAP signal like this :
Program received signal SIGTRAP, Trace/breakpoint trap.
Reset_Handler () at chibios/os/common/startup/ARMCMx/compilers/GCC/vectors.S:259
259            b          _crt0_entry
This SIGTRAP never end, if I continue I will receive this signal.
2. A boot interrupted with CTRL+C result in landing in sys.cpp:94 :
0x0800172c in systemHaltHook (msg=0x8008da0 "HardFault") at src/os/sys.cpp:94
94       os::emergencyPrint("\r\n");
And here is the bt full result :
(gdb) bt full
#0  0x0800172c in systemHaltHook (msg=0x8008da0 "HardFault") at src/os/sys.cpp:94
No locals.
#1  chSysHalt (reason=reason@entry=0x8008da0 "HardFault") at chibios/os/rt/src/chsys.c:209
No locals.
#2  0x08005858 in chibios_rt::System::halt(char const*) () at chibios/os/various/cpp_wrappers/ch.hpp:77
        reason = 0x8008da0 "HardFault"
#3  HardFault_Handler () at src/os/sys.cpp:193
No locals.
#4  <signal handler called>
No symbol table info available.
#5  0x55555554 in ?? ()
I don't understand where is located the error and where is called the hardfault handler.
If you have some time for me it would be a pleasure to discuss of this problem with you.
Best regards :).
A.
mikeprotts
Has thanked: 19 times
Been thanked: 31 times
Re: STM32L496xx | Boots issues :(
Post by mikeprotts »
Are you using a standard dev board, running one of the demo or test programs?
mikeprotts wrote:Are you using a standard dev board, running one of the demo or test programs?
Yes, that looks like a custom project setup. It is stopping on _crt0_entry which is very strange, the branch to _crt0_entry is the very first instruction executed. I would look at the linker script, the map file and check the flashed image.
Sleuek
Post by Sleuek »
I hadn't seen you answered so quickly.
I actually had a problem with Kocherga from Zubax. It was not related to Chibios.
Sorry to respond so late :(.
Thanks to both of you.
