STM32L433 GPIOH pins disabled Topic is solved
Xelus
Been thanked: 4 times
Post by Xelus »
The STM32L433 has GPIOH pins included and are disabled as this chip is defined together with STM32L432 which doesn't have GPIOH pins
This can be fixed with a #define check in
/os/hal/ports/STM32/STM32L4xx/stm32_registry.h
to enable GPIOH pins for STM32L433.
Xelus
Xelus
Re: STM32L433 GPIOH pins disabled
Post by Xelus »
Should STM32L433 and STM32L432 potentially be split?
L433 has one extra i2c and also one extra spi peripheral compared to L432.
Xelus wrote:Should STM32L433 and STM32L432 potentially be split?
Probably yes.
Xelus
Post by Xelus »
Upon further inspection, the L433 and L443 have the exact same set of peripherals. The only difference being that L443 has the hash/crypto function.
This was found in RM03943 Rev 4, page 61 of 1600.
Therefore the define for STM32L433xx on line 79
#if defined(STM32L432xx) || defined(STM32L433xx) || defined(__DOXYGEN__)
should be moved to line 300
#if defined(STM32L443xx) || defined(__DOXYGEN__)
to be changed to
#if defined(STM32L443xx) || defined(STM32L433xx) || defined(__DOXYGEN__)
Xelus
Post by Xelus »
D and E ports should also be enabled for the larger pin variants (64 and 100 pins)
Fixed as bug #1154.
Could you please verify that it is as expected? the registry changed a bit in the meanwhile.
Xelus
Post by Xelus »
Thanks, just tested. Works now.
Xelus
