[NEWS] Introducing MFS
rreignier
Has thanked: 8 times
Been thanked: 4 times
Re: [NEWS] Introducing MFS
Post by rreignier »
Ok, thank you.
There is a new version with a value of 1.
Add-EFL-driver-for-F3_v2.zip
(14.59 KiB) Downloaded 636 times
JMifune
Has thanked: 2 times
Been thanked: 2 times
Post by JMifune »
I've tried EFL-MFS tests on F407 Discovery. (Chibistudio 2021-07-RC1 trunk, GCC 10)
It successfully completes with bank_size 4096 or less, but stops @ Test Case 1.7 (Testing garbage collection by erasing) if I set the bank_size to 8192 or more.
  .bank_size        = 8192U,
  .bank0_start      = 10U, // 128K
  .bank0_sectors    = 1U,
  .bank1_start      = 11U, // 128K
  .bank1_sectors    = 1U
On L476 bigger bank size works just fine.
Exactly which step is failing in TC 17?
It could be a limit of the test case, could you try to increase MFS_CFG_MAX_RECORDS proportionally? it is 32, try making it 128.
Currently I have no way to run the test.
rreignier wrote:Ok, thank you.
Totally forgot about this....
JMifune
Post by JMifune »
Giovanni wrote:Hi,
Thanks, it helped.
Added the F3 EFL driver to trunk.
