Hi!
I've got a warning and build failure (if -Werror is used) for XMEGA hal_serial_lld.c. I think this is obvious semicolon misting bug, error should be propagated if specified flag are set:
OSAL_IRQ_HANDLER(USARTC0_RXC_vect) {
if (status & (USART_FERR_bm | USART_PERR_bm | USART_BUFOVF_bm));
set_error(&SD1, status);
ChibiOS/os/hal/ports/AVR/XMEGA/LLD/USARTv1/hal_serial_lld.c:432:3: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
[XMEGA] serial driver build failure Topic is solved
- Has thanked: 1 time
- Been thanked: 20 times
Re: [XMEGA] serial driver build failure
I think this is an issue with very recent gcc releases, you can fix it by identing the ";" like this:
Well , I think it is more than just compiler requirement. I think set_error should be executed if condition succeed
Sergio wrote:Well , I think it is more than just compiler requirement. I think set_error should be executed if condition succeed
Oh, you're right, the "set_error" should probably be inside the "if" block. I would suggest sending a patch.
- tfAteba
- Has thanked: 91 times
- Been thanked: 50 times
Hello Sergio, Utzig,
Thanks for finding this bug.
Yes if you can send a patch to fix the problem I will be happy to apply it.
Note that This driver is still in development and It nice to see that other people are interested on this architecture.
Oh, patch submit procedure is rather complex (in comparison with github process). Is there any plan to switch to more modern hosting?
- tfAteba
Re: [XMEGA] serial driver build failure Topic is solved
I Hope that some day ChobiOS will move to more modern hosting tool like you said, but for the moment we have to follow the way define by Giovanni.
Si you Can generate a patch and just attach it here!
Users browsing this forum: No registered users and 17 guests
