Using TIM15 PWM [STM32F072] Topic is solved
Re: Using TIM15 PWM [STM32F072]
The problem with the patch is that it refers CORTEX_PRIORITY_LEVELS which is defined in the RTOS port layer, it would not work in those cases where the RTOS is not present.
All required macros need to be defined in mcuconf.h.
