I2C on OLIMEX-STM32-LCD (STM32F103ZE) Topic is solved
Re: I2C on OLIMEX-STM32-LCD (STM32F103ZE)
The field "thread" has to be NULL this is intentional, it is the osalThreadSuspendTimeoutS() function that writes in it. If it hangs it is because the thread is not resumed after suspending itself.
Tuxford
Has thanked: 4 times
Been thanked: 4 times
Post by Tuxford »
Found the problem. It doesn't work with DMA. I made some small fix related to disabling DMA and it works. I suppose DMA isn't configured properly.
Giovanni, I think it has sense to add those changes to repo.
diff --git a/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c b/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c
index 57ee6db..10d29cc 100644
--- a/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c
+++ b/os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c
@@ -941,7 +941,9 @@ msg_t i2c_lld_master_receive_timeout(I2CDriver *i2cp, i2caddr_t addr,
     /* If the system time went outside the allowed window then a timeout
        condition is returned.*/
     if (!osalTimeIsInRangeX(osalOsGetSystemTimeX(), start, end)) {
+#if STM32_I2C_USE_DMA^M
       dmaStreamDisable(i2cp->dmarx);
+#endif^M
       return MSG_TIMEOUT;
@@ -955,7 +957,9 @@ msg_t i2c_lld_master_receive_timeout(I2CDriver *i2cp, i2caddr_t addr,
   /* Waits for the operation completion or a timeout.*/
   msg = osalThreadSuspendTimeoutS(&i2cp->thread, timeout);
   if (msg != MSG_OK) {
+#endif^M
   return msg;
@@ -1041,8 +1045,10 @@ msg_t i2c_lld_master_transmit_timeout(I2CDriver *i2cp, i2caddr_t addr,
       dmaStreamDisable(i2cp->dmatx);
+#endif^M
       return MSG_TIMEOUT;
@@ -1056,8 +1062,10 @@ msg_t i2c_lld_master_transmit_timeout(I2CDriver *i2cp, i2caddr_t addr,
+#endif^M
rluchyshyn@rluchyshynHP:~/Src/VVG/chibios_commercial/os/hal/ports/STM32/LLD/I2Cv1$ git diff hal_i2c_lld.c > hal_i2c_lld^C
rluchyshyn@rluchyshynHP:~/Src/VVG/chibios_commercial/os/hal/ports/STM32/LLD/I2Cv1$ Giovanni^C
rluchyshyn@rluchyshynHP:~/Src/VVG/chibios_commercial$
rluchyshyn@rluchyshynHP:~/Src/VVG/chibios_commercial$ git diff hal_i2^C
rluchyshyn@rluchyshynHP:~/Src/VVG/chibios_commercial$ git diff os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c
+#endif^M
       return MSG_TIMEOUT;
+#endif^M
   return msg;
+#endif^M
       return MSG_TIMEOUT;
+#endif^M
rluchyshyn@rluchyshynHP:~/Src/VVG/chibios_commercial$ git diff os/hal/ports/STM32/LLD/I2Cv1/hal_i2c_lld.c > hal_i2c_lld.patch
cat hal_i2c_lld.patch
+#endif
       return MSG_TIMEOUT;
+#endif
   return msg;
+#endif
       return MSG_TIMEOUT;
+#endif
   return msg;
Moving this to "bug reports".
In I2Cv1 there is no STM32_I2C_USE_DMA, are we talking about a customized driver?
Closing.
