Reading incorrect serial data from external program
oszfather
Has thanked: 2 times
Postby oszfather » Wed Jul 06, 2022 7:03 pm
I have a seperate C++ desktop application that is able to open com port connected to the stm32. the stm32 is transmitting serial data. The serial data is "12345". The C++ program should display this with the letters S and E surrounding it (to indicate start and end of recieved data).
The code for the serial config and transmission thread :
/* Serial configuration. */
static const SerialConfig myserialcfg = {
  115200,
  0,
  USART_CR2_STOP1_BITS,
  0
static THD_FUNCTION(ThdSerial, arg) {
  (void) arg;
  chRegSetThreadName("Serial manager");
  /* Configuring VCP related GPIO. This configuration is already
     performed at board level initialization but is here reported
     only as example of how to configure GPIO at application level. */
  palSetPadMode(GPIOA, 2U, PAL_MODE_ALTERNATE(7) | PAL_STM32_OSPEED_HIGHEST |
                           PAL_STM32_OTYPE_PUSHPULL);
  palSetPadMode(GPIOA, 3U, PAL_MODE_ALTERNATE(7) | PAL_STM32_OSPEED_HIGHEST |
  /* Starting Serial Driver 2 with our configuration. */
  sdStart(&SD2, &myserialcfg);
  while(true) {
      chprintf(chp, "12345");
      chThdSleepMilliseconds(20);
Main thread:
int main(void) {
  palSetPadMode(GPIOA, 1, PAL_MODE_INPUT_ANALOG);
  palSetPadMode(GPIOA, 8, PAL_MODE_ALTERNATE(1));
  // Serial thread
  chThdCreateStatic(waThdSerial, sizeof(waThdSerial), NORMALPRIO+1, ThdSerial,NULL)
  while (true) {
    chThdSleepMilliseconds(2);
I've noticed the data is only being read by the C++ program correctly when the thread sleep function in the serial thread is 20ms (from trial and error) ( chThdSleepMilliseconds(20) )
When it is 5ms. The c++ application reads the data multiple times in one instance like so:
 S12345123451234512345E S123451234512345E S12345123451234E S5123451234512345E S123451234512345E S123451234512345E S1234512345123451234512345E S1234512345E S123451234512345E
When it is raised to 35ms some of the incoming data is skipped like so:
 SE S12345E SE S12345E SE S12345E SE S12345E SE S12345E SE S12345E SE S12345E SE SE S12345E SE S12345E SE S12345E SE S12345E SE S12345E S12345E SE
Why is this happening and how can i make it so that whatever the length of the message that needs to be sent isn't related to the delay time so both short and long messages arrive in one complete instance?
(as a note, there is no sleeping on the C++ application side. It is polling 24/7)
Has thanked: 1146 times
Been thanked: 960 times
Re: Reading incorrect serial data from external program
Postby Giovanni » Wed Jul 06, 2022 8:50 pm
If you read the data with a serial terminal emulator, do you read the correct data? if so the problem is on the desktop application side.
Note that the serial driver is buffered and does not depend on timings data is queued and the writer thread would simply wait if the buffer is full.
oszfather
Postby oszfather » Thu Jul 07, 2022 5:18 pm
Giovanni wrote:Hi,
Yes, the application side was where the issue was, thanks. While on the subject of serial communication. I'm trying to read info back from the desktop app. The desktop app is sending the string "message". What is the proper usage of sdRead(sdp,b,n) ?
  static char str[255];
  while(true) {
    sdRead(&SD2, str,255);
    chprintf(chp, "recieved: %s \r\n", str);
the sdRead function here is blocking and nothing gets printed. How should it be written instead? is it preferable to use sdGet and append each incoming character to a char[] array especially if each incoming string varies in length?
Postby Giovanni » Thu Jul 07, 2022 7:15 pm
Serial communication is not that easy, you cannot assume that the 2 parties are in synch, if try to ready 6 bytes and the sender only sends 5 then the receiver is stuck indefinitely.
Some possible approaches:
- Use timeouts on receive.
- Use message delimiters, for example lines of text ended by a CR.
In general design a state machine for your serial protocol, you need to handle cases such as loss of sync, lost chars, communication errors. An ideal protocol should be able to recover from all those kind of things.
oszfather
Postby oszfather » Thu Jul 07, 2022 7:21 pm
Giovanni wrote:Hi,
Thanks for the advice. I've managed to recieve the "message" string using the timeout version of the sdRead function. Lastly is there some kind of condition I can check or a function that gets called ONCE when a string arrives.
 int8_t wordcount = 0;
  while(true) {
    sdReadTimeout(&SD2, str, 255, TIME_MS2I(50));
    if(strcmp( str,"message")==0) {
      wordcount++;
    chprintf(chp, "recieved: %d £%s£ \r\n", wordcount,str);
    chprintf(chp, "ok");
the if statement just checks is str is equal to message and increments 'wordcount' forever. Is there some method that is run once upon arrival of a string so wordcount is incremented once whenever "message" is recieved?
psyco
Been thanked: 11 times
Postby psyco » Thu Jul 07, 2022 11:26 pm
What is happening is the sdReadTimeout call is timing out due to receiving no bytes and not modifying your buffer, leaving the "message" string from the reception untouched and still valid. You need to check the return value of sdReadTimeout (which calls iqReadTimeout) which is the number of bytes actually received by the application (similar to POSIX read, or Windows ReadFile's lpNumberOfBytesRead out value):
http://chibiforge.org/doc/21.11/hal/gro ... 01a13277d6
However, you'll likely have another issue of dropped messages. This would be due to the message not aligning with the 50 ms timeout (for example, the last byte might arrive at 51 ms after the call to sdReadTimeout, just after the timeout). You could split the reads into two, the first reading just one byte (with or without a timeout), and the second reading the rest of the bytes if the first one read a byte (this time with the timeout).
I agree with Giovanni that you should frame / packetize your data somehow so the receiver can resync to the data stream. Timing serial like that isn't extremely reliable from a computer.
Return to “ChibiOS/HAL”
Users browsing this forum: No registered users and 44 guests
