How to get rid of error: selected ST frequency is not obtainable because integer rounding Topic is solved
robert_o
Been thanked: 5 times
Postby robert_o » Sun Sep 18, 2022 7:39 pm
I have a STM32F411CE (blackpill Board) with HSE=25MHz.
I selected M=15, N=144, P=4, Q=5, AHBP=1, APB1=2, APB2=1 which gives 60MHz System Clock and 48MHz USB Clock.
I've got the Error:
chibios_trunk/os/hal/ports/STM32/LLD/TIMv1/hal_st_lld.c:322:2: error: #error "the selected ST frequency is not obtainable because integer rounding"
which comes from:
#if ST_CLOCK_SRC % OSAL_ST_FREQUENCY != 0
Chibios uses Timer 2 (32bit).
How can i fix this?
Robert
robert_o
Re: How to get rid of error: selected ST frequency is not obtainable because integer rounding  Topic is solved
Postby robert_o » Sun Sep 18, 2022 7:53 pm
Never mind.
I found a solution with:
M=25, N=192, P=2, Q=4 which gives 96MHz System Clock and no error.
cheers.
Has thanked: 1146 times
Been thanked: 960 times
Postby Giovanni » Sun Sep 18, 2022 7:56 pm
That assertion is about the system tick frequency defined in chconf.h, the frequency must be obtainable from the selected timer. Consider that the timer prescaler is 16 bits even on 32 bits timers.
robert_o
Postby robert_o » Sun Sep 18, 2022 8:09 pm
Thanks for the reply. I don't understand.
With 60Mhz Timer freq and 10kHz Systick the prescaler could be 6000?
Why is this not obtainable?
Postby Giovanni » Sun Sep 18, 2022 8:23 pm
25MHz / 15 is not an integer value, the preprocessor uses integer math and gives 1666666, after multiplying by 144 the result is 239999904.
robert_o
Postby robert_o » Sun Sep 18, 2022 8:28 pm
Thank you for the explanation.
-robert
Return to “STM32 Support”
Users browsing this forum: No registered users and 156 guests
