STM32F103C8T6 I2C halting with "priority prder violation" Topic is solved
ManWithACrowbar
Post by ManWithACrowbar »
Hello, everyone. I was trying to implement a simple I2C scanner using ChibiOS v. 7.0.5 on STM32F103C8T6 using custom build environment (CMake-based). I ran into issue, when I try to scan the bus, chSysUnlock() in i2cReleaseBus fails on assert "priority order violation". I do not understand, what am I doing wrong, since I am not using any locking in my own code whatsoever. Could anyone please help me resolve the issue? Code can be accessed by link: https://github.com/PortiaLabiata/katetris. Thanks!
Re: STM32F103C8T6 I2C halting with "priority prder violation"
You are getting a ready list corruption probably caused by invalid API usage, try enabling the "state checker" in chconf.h and verify if there are context violations.
ManWithACrowbar
Thank you for your reply. State checking is already enabled and doesn't seem to fire (as I understand, it is supposed to halt system in case of a context violation, but halt happens from here:
[spoil]#0 chSysHalt (
reason=reason@entry=0x8006e78 <__func__.4> "chSysUnlock")
at /home/portia_labiata/katetris/chibios/os/rt/src/chsys.c:232
#1 0x08004ee6 in chSysUnlock ()
at /home/portia_labiata/katetris/chibios/os/rt/include/chsys.h:430
#2 chMtxUnlock (mp=mp@entry=0x200020cc <I2CD1+12>)
at /home/portia_labiata/katetris/chibios/os/rt/src/chmtx.c:396
#3 0x08001c0e in osalMutexUnlock (mp=0x200020cc <I2CD1+12>)
at /home/portia_labiata/katetris/chibios/os/hal/osal/rt-nil/osal.h:1082
#4 i2cReleaseBus (i2cp=i2cp@entry=0x200020c0 <I2CD1>)
at /home/portia_labiata/katetris/chibios/os/hal/src/hal_i2c.c:297
#5 0x080002c6 in i2c_scan ()
at /home/portia_labiata/katetris/display.c:35
#6 0x0800017e in thd_video (arg=<optimized out>)
at /home/portia_labiata/katetris/main.c:27
#7 0x080041ca in __port_thread_start ()
at /home/portia_labiata/katetris/chibios/os/common/ports/ARMv7-M/compilers/GCC/chcoreasm.S:203[/spoil]
Check for possible stack overflows also, try increasing stacks and see if there is change.
ManWithACrowbar
I found the issue, appearently I forgot to divide sizeof of int array by sizeof(int), which caused loop to go over a huge chunk of RAM, likely corrupting ready list in the process. Thank you, please close the thread.
