NIL 21.11.4 - CH_PORT_SUPPORTS_RECURSIVE_LOCKS? Topic is solved
drizzi
Has thanked: 2 times
Been thanked: 5 times
Post by drizzi »
maybe I have found a bug in NIL. In ch.h CH_PORT_SUPPORTS_RECURSIVE_LOCKS is defined TRUE only #if defined(port_get_lock_status) && defined(port_is_locked), but both port_get_lock_status and port_get_lock_status are always NOT defined, as there is no #include "chcore.h" (differently from RT, where the same is done in chport.h, and that includes chcore.h).
Ciao,
Davide
Re: NIL 21.11.4 - CH_PORT_SUPPORTS_RECURSIVE_LOCKS?
Which port are you referring to? some ports do not define those macros intentionally.
drizzi
Post by drizzi »
the port is ARMv7-M. Both port_get_lock_status and port_is_locked are defined in chcore.h. But, since that file is not included in os/nil/include/ch.h, CH_PORT_SUPPORTS_RECURSIVE_LOCKS is always defined as FALSE.
Hi,m
Fixed in 21.11.x and 20.3.x. Trunk was not affected.
