Respect request wLenght
Subject: [PATCH] usb: truncate string descriptor response to match
setup.wLength
Windows requests the first 2 bytes of a string descriptor to read
its size before asking for the full string. This fix ensures the
firmware truncates the response data to match wLength, preventing
endpoint stalls and timeouts on strict hosts.
os/hal/src/hal_usb.c | 6 +++++-
1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/os/hal/src/hal_usb.c b/os/hal/src/hal_usb.c
index 033977449..173a83d54 100644
--- a/os/hal/src/hal_usb.c
+++ b/os/hal/src/hal_usb.c
@@ -126,6 +126,8 @@ static bool default_handler(USBDriver *usbp) {
return true;
case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_GET_DESCRIPTOR << 8):
case (uint32_t)USB_RTYPE_RECIPIENT_INTERFACE | ((uint32_t)USB_REQ_GET_DESCRIPTOR << 8):
+ size_t wLength;
/* Handling descriptor requests from the host.*/
dp = usbp->config->get_descriptor_cb(usbp, usbp->setup[3],
usbp->setup[2],
@@ -133,10 +135,12 @@ static bool default_handler(USBDriver *usbp) {
if (dp == NULL) {
return false;
+ wLength = get_hword(&usbp->setup[6]);
/*lint -save -e9005 [11.8] Removing const is fine.*/
- usbSetupTransfer(usbp, (uint8_t *)dp->ud_string, dp->ud_size, NULL);
+ usbSetupTransfer(usbp, (uint8_t *)dp->ud_string, wLength < dp->ud_size ? wLength : dp->ud_size, NULL);
/*lint -restore*/
return true;
case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_GET_CONFIGURATION << 8):
/* Returning the last selected configuration.*/
usbSetupTransfer(usbp, &usbp->configuration, 1, NULL);
2.43.0
