Why my Heap is empty?
noether
Post by noether »
I am integrating the DSP_LIB from ARM with ChibiOS, and I have a strange behavior (well, probably it is normal but I can not explain it).
I have the next main (is a ripped version of the demo for the STM32F4 Discovery).
#include <math.h>
#include "ch.h"
#include "hal.h"
#include "./math/arm_math.h"
#include "./math/matrix.h"
static MemoryHeap *matricesHeap;
static float matricesBuff[4*1024*sizeof(float)];
  (void)arg;
  while (TRUE) {
    palSetPad(GPIOD, GPIOD_LED3);       /* Orange.  */
    chThdSleepMilliseconds(500);
    palClearPad(GPIOD, GPIOD_LED3);     /* Orange.  */
int main(void) {
    float x = 0.3f;
    uint8_t led = 0;
    systime_t t1tick;
    systime_t t1lapse;
    chHeapInit(matricesHeap, matricesBuff, 4*1024*sizeof(float));
    arm_matrix_instance_f32 A, B, C;
    matrixInit(&A, 2, 2, matricesHeap);
    matrixInit(&B, 2, 2, matricesHeap);
    matrixInit(&C, 2, 2, matricesHeap);
    A.pData[0] = 1.1f;
    A.pData[1] = 2.1f;
    A.pData[2] = 4.1f;
    A.pData[3] = 5.1f;
    B.pData[0] = 3.1f;
    B.pData[1] = 4.1f;
    B.pData[2] = 5.1f;
    B.pData[3] = 7.1f;
    while (TRUE) {
        arm_status status;
        t1tick = chTimeNow();
        x = x + sinf(x);
        status = arm_mat_add_f32(&A, &B, &C);
        arm_copy_f32(C.pData, A.pData, A.numRows*A.numCols);
        led = !led;
        if(led){
            palSetPad(GPIOD, GPIOD_LED4);       /* Green.  */
        else{
            palClearPad(GPIOD, GPIOD_LED4);     /* Green.  */
        t1lapse = GetTimeInterval(&t1tick);
        if(t1lapse < MS2ST(500))
            chThdSleepUntil(t1tick + MS2ST(500));
        else
            palSetPad(GPIOD, GPIOD_LED5);
The code is working as expected, just doing A+B = C, A = C, each iteration.
But, when I look at the Heap (matricesBuff) with gdb is just empty:
    (gdb) p matricesBuff
    $89 = {0, 2.29476637e-41, 0 <repeats 16382 times>}
Here it is the initialization code for the matrices
void matrixInit(arm_matrix_instance_f32 *m, int rows, int cols,
        MemoryHeap *memoryHeap) {
    float32_t *data;
    data = (float32_t *)chHeapAlloc(memoryHeap,
            rows*cols*sizeof(float32_t));
    arm_mat_init_f32(m, rows, cols, data);
The arm_mat_init just pass the data to the structure arm_matrix_instance_f32.
Probably I am missing how the management of the Heap works in ChibiOS, but... should matricesBuff not be populated with the values of A, B and C?
By the way, these are the pointers given to A, B, and C:
    (gdb) p/u A.pData
    $91 = 536939968
    (gdb) p/u B.pData
    $92 = 536939992
    (gdb) p/u C.pData
    $93 = 536940016
Why the distance between each other is 24 and not 16 (corresponding to 4 floats)?
Thanks in advance for your help!
Re: Why my Heap is empty?
You are passing to chHeapInit() a MemoryHeap* pointing to nothing not a pointer to a statically allocated MemoryHeap, you would write chHeapInit(&matricesHeap, matricesBuff, 4*1024*sizeof(float)) in that case.
noether
Post by noether »
Giovanni wrote:Hi,
Thank you very much Giovanni, it was really a quick response!
In the first code I have defined: static MemoryHeap *matricesHeap;
this is why I have passed as argument to the chHeapInit without & .
I am not a experienced programmer, so many thanks for catching the mistake.
Now I can see in the Heap the values of the A, B and C matrices, but I still seeing "two holes" among them.
    $107 = {1.08459922e-19, 2.24207754e-44, 1.10000002, 2.0999999, 4.0999999,
    5.0999999, 1.08459922e-19, 2.24207754e-44, 3.0999999, 4.0999999, 5.0999999,
    7.0999999, 1.08459922e-19, 2.24207754e-44, 0, 0, 0, 0, 0, 2.28467702e-41,
    0 <repeats 16364 times>}
Why is it not well aligned?
Thanks again in advance.
The allocator maintains its own data into the 8 bytes before the allocated block, the real used memory is size+8.
Do not assume that allocated blocks are contiguous and do not assume that all the space reserved for the heap is entirely available.
noether
Post by noether »
Giovanni wrote:The allocator maintains its own data into the 8 bytes before the allocated block, the real used memory is size+8.
Thank you very much for the explanation. I will be conservative for my estimations then.
