hi@all
i've just started with ARM + chibiOS and isntlaled the whole toolchain for that in a virtual appliance.
perhaps it can be usefull for someone else, to start with chibiOS?
it contains lubuntu + arm gcc + stlink + eclipse + chibiOS 2.4
and an easy example project with 2 chibios threads for the STM32f4Discoveryboard
one mouseclick is enough to build, flash and debug the project.
but I have some problems with the debugging. I can step throu the code but my own breakpoints wil ignored by the debugger
(optimisation is deactivated)
if someone want the image just write me an email at benwilliam (at) freenet.de
vmware image: easy start with chibiOS
Re: vmware image: easy start with chibiOS
Nice work, thanks for sharing!
When you have some spare time, I'd be interested in this, but as a virtual box image
benwilliam
virtualbox can use vmware images directly
if it doesn't work you can try to convert it
//convert .vmdk in binary File
qemu-img convert /path/to/original.vmdk -O raw converted.bin
//convert .bin in .vdi Virtualbox File
VBoxManage convertdd converted.bin converted.vdi
Didn't took a look yet. but thank you very much!
I guess by doing I can also use it in qemu?
I guess by doing
qemu-img convert /path/to/original.vmdk -O raw converted.bin~ Tectu
