GDISP driver
inmarket
Re: GDISP driver
Post by inmarket »
Just did a pull request for the back-ported ssd1289 low level driver.
As I don't have that hardware can someone please compile and test for me.
Abhishek
Re: GDISP driver
Post by Abhishek »
@Tectu, the script given is just to convert the font table from the old fmt to the new format. Unfortunately. It can't generate a font table by itself!
inmarket
Re: GDISP driver
Post by inmarket »
Abhishek wrote:Since only you are under control of your code right now ;) , how would you go about it with your current framework?
Probably create sub-directories under halext/drivers.
The devil is in the detail and we will get the best feel for it when we first try it.
Hopefully in the next few days I get a chance to think more about it.
Re: GDISP driver
Dosen't anybody of you windows guys use a font generator? Abhsishek, afaik you did? Couldn't you make a few more fonts?
Abhishek
Re: GDISP driver
Post by Abhishek »
@Tectu, the font generator I used supports 16bit fonts only :( . However if you want to try out a new style like Comic Sans, i'll give you.
@inmarket, if you do the S6D1121, I might give it a try on Thursday.
inmarket
Re: GDISP driver
Post by inmarket »
Tectu wrote:Dosen't anybody of you windows guys use a font generator? Abhsishek, afaik you did? Couldn't you make a few more fonts?
I vagely remember microwindows (google it) use to have a bitmap font generator (at least before they switched to true-type bloat). If that is still around it could be merged with my utility previous posted to create fonts ad-infinitum.
inmarket
Re: GDISP driver
Post by inmarket »
Abhishek wrote:@Tectu, the font generator I used supports 16bit fonts only :( . However if you want to try out a new style like Comic Sans, i'll give you.
Are you able to make this generally availble?
If copyright allows perhaps we could create a tools directory and add it to that?
Abhishek wrote:@inmarket, if you do the S6D1121, I might give it a try on Thursday.
I'll try to get to it tomorrow if my day isn't too busy.
Abhishek
Re: GDISP driver
Post by Abhishek »
Get it from here: http://reifel.org/picuserinterface/
My text rendering code was based on this one.
inmarket
Re: GDISP driver
Post by inmarket »
Just added new pull request for a number updates including new low level driver s6d1121.
inmarket
Re: GDISP driver
Post by inmarket »
Abhishek wrote:Get it from here: http://reifel.org/picuserinterface/
Thanks, it was very helpful. I have one more low level driver to do for gdisp (the Nokia6100), some testing to do and then I'll look at creating a font generator in that style. I will write it in java so that it will run on both Windows and Linux. I also need to catch up on some sleep soon :)
In the latest upload I have extracted the font structure definitions into a nice standalone include file so that it can also be included in any font tools written. I also included a define so that you can rebuild using up to 32 bit high fonts instead of 16 (the default).
Locked
