Chibios 2.4.1 : Eclipse Invoking Command : make all
Cyrille
Post by Cyrille »
Hi all,
I encounter a problem using Eclpise Helios with the 2.4.1 chibios rev. (this was not the case with the old chibios 2.2 rev)
When I build my project (or a testhal example), eclipse (CDT) spent time during the "Building project...: Invoking Command : make all". I wait about 1 min for the first compiled line. I precise that I have configure Eclipse as recommended on the chibios website.
Does anybody has observed the same problem ?
Re: Chibios 2.4.1 : Eclipse Invoking Command : make all
No, it must be something specific to your setup. If you use Windows, in the download area on SF you can find "Chibi Studio", it is an Eclipse environment based on Eclipse Juno with the compiler and all the required tools, it also include the latest ChibiOS.
You may give it a try (just unzip it under C:\) and see if the problem persists.
Cyrille
Post by Cyrille »
By using the Chibi Studio with start.bat has solved my problem. Compiling my code takes about 4 sec.
Chibi Studio, uses the "parallel build" by default, if you are on a multicore PC you should experience much faster builds.
