Need help for serial usb
odie
Post by odie »
I need your help for your serial usb driver.
I want to send a serial message for a GPS over usb.
First I copy your USB_CDC test code, but how can I send a serial message?
Regards,
Odie
mabl
Re: Need help for serial usb
Post by mabl »
Hello Odie,
do you intend to connect the GPS device to the USB socket? If so, that will probably not work. The usb serial interface is meant to connect to a computer.
Regarding how to write to the serial usb driver: I think SerialUSBDriver implements a BaseAsynchronousChannel, so you can use it the same way as every serial driver.
odie
Post by odie »
Hello mabl,
I am so stupid. Now I use sdAsynchronousWrite() and it works fine.
Thanks for your help!
