GDISP driver
colombo
Re: GDISP driver
Post by colombo »
Hi Abhishek,
thank you for your reply.
Abhishek wrote:Here's the pin assignment, hope this should clear your confusion:
FSMC_NWE = WR Signal of LCD
FSMC_NOE = RD Signal of LCD
FSMC_NE1 = CS Signal of LCD
Good :)
Abhishek wrote:The Address pin is connected to RS which is the A16 pin on the F4
I was lost D11 pin alternate and the comment /* Using FSMC A16 as RS */
Abhishek wrote:And yes, you're right. We'll update the code soon, so that the I/O layer for all the FSMC/GPIO drivers for the QVGA LCDs and SSD1963 is in sync.
Thank you for this work.
I see in STM32F4Discovery some pins of FSMC is shared with other peripherals, for example PD4/FSMC_NOE is connected to Audio_Rst and has a 10K(R43) pull-down.
Does not create problems?
Another doubt
#define LCD_REG (*((volatile uint16_t *) 0x60000000)) /* RS = 0 */
#define LCD_RAM (*((volatile uint16_t *) 0x60020000)) /* RS = 1 */
0x60020000 => 1100000000000100000000000000000
Does set A17? Is it correct?
Best Regards
colombo
Badger
Re: GDISP driver
Post by Badger »
colombo wrote:I see in STM32F4Discovery some pins of FSMC is shared with other peripherals, for example PD4/FSMC_NOE is connected to Audio_Rst and has a 10K(R43) pull-down.
On my board I removed the chips, resistors etc that had shared features with FSMC. I'm not sure if it was necessary, I did it as part of troubleshooting whilst implementing the FSMC code and found the problem to be elsewhere, but didn't bother putting the chips back.
Another doubt
I was also somewhat confused by this convention, but it does indeed seem to be correct, even if it goes against intuition.
mobyfab
Has thanked: 21 times
Been thanked: 31 times
Re: GDISP driver
Post by mobyfab »
I only removed the USB over current resistor
The address pin is A16.
Re: GDISP driver
Thanks for your contribution, Mobyfab!!!
mobyfab
Re: GDISP driver
Post by mobyfab »
Tectu wrote:Thanks for your contribution, Mobyfab!!!
You're welcome ;)
Now working on GWEN :D
colombo
Re: GDISP driver
Post by colombo »
mobyfab wrote:I only removed the USB over current resistor
47K R51 Pull-up 3V. Rigth?
mobyfab
Re: GDISP driver
Post by mobyfab »
Don't remember, check on the discovery datasheet :)
Otherwise I have started integrating GWEN to ChibiOS: http://github.com/mobyfab/ChibiOS-Gwen
It compiles but does nothing as I haven't really started to port it.
it *should* not be too complicated to port.
There is an example here: https://github.com/mobyfab/ChibiOS-Examples/tree/master/STM32F4-LCD-GWEN
FYI the code is around 308k with GWEN displaying a skinned button.
The gdisp demo is 14k in C, 245k in C++. So the GWEN overhead is around 63k.
miguelmoreto
Re: GDISP driver
Post by miguelmoreto »
To Badger and colombo:
This address sets A16. FSMC controller shifts it right by 1 when FSMC is used to address data of 16bits. See Table 164, page 1227 of STM32F407VG reference manual (document DM00031020).
I had the same doubt until reading this FSMC documentation.
Best regards,
Miguel
Badger
Re: GDISP driver
Post by Badger »
miguelmoreto wrote:This address sets A16. FSMC controller shifts it right by 1 when FSMC is used to address data of 16bits. See Table 164, page 1227 of STM32F407VG reference manual (document DM00031020).
I spent a little while trying to understand what was going on, thanks for the explanation :oops:
mobyfab
Re: GDISP driver
Post by mobyfab »
Found out the string class is taking up around 120k of code :lol:
I'll try to find an alternative, much lighter class.
The C++ example takes 18K of code without the string class or using new.
with new it goes up to 90K of code.
Locked
