Giovanni wrote:There are three new configuration option that should be considered when using this driver.
Do you mean "txpending", "thd_ptr" and "thd_wait" ? Those are the only new options I found and as far as I can tell I don't have to fiddle with them at all.
Without changing anything, the new driver works like a charm, many thanks for improving it, much appreciated!
@Kjell I'm still trying to use the asynchronous libUSB api, but I don't have much free time to do so. If you get something working, I'd be happy to test your code.
*edit* I have an asynchronous version ready, but it uses ~20x more CPU power, because its braindead implemented. I'll push it when its fixed.
