Chibi-Studio Configuration Tool
Pilt
Post by Pilt »
I am trying to use the configuration tool in Chibi-Studio but appear not to be having any luck.
I open one of the Demo projects and select New -> Other -> ChibiOS/RT Configuration Tool and select my board (STM32L). The xml file opens up in the design view of the editor but I do not get the .xsd view as shown in your screen shots.
I have installed the FMPP tool (as mentioned in another post), so I cannot work out why this is not working, any ideas?
Dan
Re: Chibi-Studio Configuration Tool
The XML editor has a text view and a design view, you can switch them using the tabs in the lower side of the window. You don't need to install anything, it is all installed in ChibiStudio.
Edit your XML in the editor then generate the board files using a button in the tool bar that appears only when you select a .chcfg file (it also appears as a configuration menu).
