STM32F4 discovery use both usb otg interfaces
GZUnbekannt
Post by GZUnbekannt »
Hello Chibios-Community ;)
I'm currently trying to make use of the second usb OTG interface of the stm controller.
The slower (full speed) should be used as a virtual com port, the faster one as a usb-memory interface.
Is there already an implementation of the second interface?
I'm using chibios 2.5.2 from svn ;)
Looking forward for replays :)
Greetings ;)
Re: STM32F4 discovery use both usb otg interfaces
Both are supported, but OTG HS is only supported in FS mode, the HS mode has never been tested because it requires an external PHY and probably a custom board.
GZUnbekannt
Thank you for your fast replay!
Ok, i wanted to use one as Host and one for the serial interface, but okay, i've to go another way ;)
Greetings GZUnbekannt :)
