What is the equavalint code of the memmory allocation
robu
Re: What is the equavalint code of the memmory allocation
Post by robu »
Thank you very much for your answer,
I tried your solution, now I'm getting the following errors:
make all
Linking build/ch.elf
/opt/arm_gcc/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/lib/libc.a(lib_a-abort.o): In function `abort':
abort.c:(.text+0x10): undefined reference to `_exit'
/opt/arm_gcc/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/lib/libc.a(lib_a-signalr.o): In function `_kill_r':
signalr.c:(.text+0x1c): undefined reference to `_kill'
/opt/arm_gcc/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/lib/libc.a(lib_a-signalr.o): In function `_getpid_r':
signalr.c:(.text+0x44): undefined reference to `_getpid'
make: *** [build/ch.elf] Error 1
Which library do I have to include to solve this error? I also posted on the stackexchange but I haven't receive any good answer yet.
Thank you.
Robert
mabl
Post by mabl »
Those are missing newlib stubs. Try to include syscall.c/h in your makefile. It's provided with ChibiOS
robu
Post by robu »
I already did, before I had 6 error messages, the syscall.c reduced to 3. Where else can I find this functions?
mabl
Post by mabl »
Have a look here:
viewtopic.php?f=2&t=793&p=7778#p7762
Giovanni, i guess we should really look into extending the stubs properly... Prof. Yo Man, didn't you look into this already?
Prof. Dr. YoMan
Post by Prof. Dr. YoMan »
Well, what I posted in one thread is the maximum to do, when you want correct locking without recompiling newlib.
To do it right, there should be a recompiled newlib especially for ChibiOS (using chmalloc, ... correct locking, ... maybe more POSIX stuff), which would be a major effort for all supported plattforms.
I decided to live with the drawbacks and to use my mind to not fall into pitfalls. :)
robu
Post by robu »
Thanks mabi, this is working.
