registering a new interrupt handler at runtime
hazelnusse
Re: registering a new interrupt handler at runtime
Post by hazelnusse »
Ok, I think I found a solution I am happy with. In my linker script, I have:
    ram_startup : ALIGN(16) SUBALIGN(16)
        __ram_vector_table_start__ = .;
        KEEP(*(ram_vectors))
    } > ram AT > flash
Note that you must have "> ram AT > flash" NOT "> ram" as I had in my previous post.
Then, in my chconf.h, I have:
extern uint32_t __ram_vector_table_start__;
#define CORTEX_VTOR_INIT __ram_vector_table_start__
Then all seems to work correctly. If I look at my map file, I can see:
                0x0000000020000800                __ram_vector_table_start__ = .
 *(ram_vectors)
 ram_vectors    0x0000000020000800      0x200 build/obj/VectorTable.o
__ram_vector_table_start__                        build/obj/chcore_v7m.o
The nice thing about this approach is that if I change the stack sizes in the linker script, SCB_VTOR still gets correctly initialized with the right value.
I'm going to test it to make sure, but I think this looks pretty good. Any thoughts?
Luke
Probably it should be:
#define CORTEX_VTOR_INIT &__ram_vector_table_start__
You have to refer the address of the variable.
hazelnusse
One thing I am a bit confused about still is the alignment of the vector table. For the STM32F4, there are 16 + 82 interrupt vectors. My understanding of the vector table is that it must be aligned to the vector table size, extended to the next larger power of 2. So that would be 4*(16+82) = 392, extended to the next larger power of 2 would be 512. In the linker script there are alignment statements like
but in the place where I declare the vector table, I have this:
static vectors_t vtable_ __attribute__((aligned(512)));
So I'm a bit confused as to which one does what. The map indicates that the vector table is on a 512 byte boundary, so I guess I'm ok, but I tried experimenting with changing the values in ALIGN(), SUBALIGN(), and __attribute__((aligned())) and couldn't really see which one has control over where the vector table gets placed. Also, if I make the stack sizes such that they are just past a 512 byte boundary, and only specify 16 byte alignment (in all three places), I still get 512 byte alignment for some reason..... Very confusing. I must be missing something here.
I changed to be &__ram_vector_table_start__. In the context of the linker script, this variable is the location counter at the beginning of the ram_startup section, so I'm a bit confused as to why we need the address of this variable and not the value. Must be another subtlety of linker scripts that I'm not clear on.
Luke
Luke
