Hello all,
I have a thread which stays in wait state, until an event is fired. So, in this thread I use
eventmask_t e = chEvtWaitOne(3);
which should stand for: wait for eventmask 1 or 2... is this right?
In interrupt routine, I fire events through:
chEvtSignalFlags(thread_in_wait, 1);
or
chEvtSignalFlags(thread_in_wait, 2);
Problem is I always receive 1. Is it possible to decode the originated event?
-g
How to find originated event
Re: How to find originated event
The only error I see is that you should use chEvtSignalFlagsI() from an ISR, doesn't the state checker complain about that?
The function chEvtWaitOne(3) should return you 1 or 2 depending on the signaled flags, are you sure that signaling 2 is really executed?
Well, I did as you wrote and now I get both of the events simultaneously.
I set the thread priority to HIGH level, but I still get both of the events at the same time.
Is the interrupt routine signaling events too fast?
chEvtWaitOne() should only return an event each time, a single bit at 1 in the returned mask (and it is not matter of speed). chEvtWaitAny() would return all the pending bits at once.
It is very strange chEvtWaitOne() returning 3, are you sure?
Ok, I solved it by removing a chevtclearflags I tried before.
just for information: where could I find more info about "state checker"?
-g
-g
It is one of the debug options found in chconf.h, it verifies that the various APIs are called from the right context, for example S-class and I-class APIs called from within a lock.
It is mentioned in this article: http://www.chibios.org/dokuwiki/doku.ph ... ebug_guide
