STM32F4DISCOVERY and DP83848 Pocket loss at ~40%
[email protected]
- Been thanked: 1 time
Hi ALL!
First of all thank you for bringing the ethernet functionality to Chibios/RT. It's very useful.
I have a couple o STM32F4DISCOVERY boards and a DP83848 connected to one of them.
I have started with ARMCM4-STM32F407-LWIP example changing it as described 3 posts earlier to let this work with my DISCOVERY board.
It was piece of cake. Everything have compiled, uploaded to MCU and started as it should.
The example page is available as it should. But unfortunately the amount of lost package is at about 40%. I have tested it with many examples:
1. simple pinging w/o any spiecial parameters
2. embeeded site request from my PCs web browser
3. written another example, which was requesting a HTTP GET from MCU to external server
A simple ping result of command: #ping 192.168.1.20 (NO EXTRA ARGS, just basic test):
--- 192.168.1.20 ping statistics ---
546 packets transmitted, 329 received, 39% packet loss, time 545002ms
rtt min/avg/max/mdev = 0.073/0.124/2.841/0.161 ms
In all cases the problem was exacly same: it is working fluently for ex. 10 seconds, then for 5 secs. nothing (pocket loss), again ok for some seconds, then again nothing form some seconds and all over again.
When everything is working ok- no packet loss (20s max), then it is working very fast.
I have tested it using the latest trunk of Chibios/RT and both LWIP 1.4.0 and .1.4.1. Whatever i do i am having very same problem: pocket flood, nothing, pocket flood, nothing......
It doesn't seem to be a hardware problem I think.
Any ideas what to check? How to debug?
BTW. This is a copy of the post from Ethernet development topic, as Giovanni requested.
Greetings
Piotr Klimczak
Greetings
Piotr Klimczak
Re: STM32F4DISCOVERY and DP83848 Pocket loss at ~40%
I try to redo the ping test, I already did it in the past but I didn't notice anomalies until I started to do packet serious flooding (20 pings in parallel with no interval and very large packets).
Could it be a problem related yo your PHY or the clock driving it?
[email protected]
To check is it a PHY hardware problem I have to buy another one. This is what i want to avoid as i will make a use only for one PHY.
I am using this module: http://arduinosolutions.com/index.php?r ... uct_id=235
Unfortunately i do not understand what do you mean "the clock driving".
Thanks for your help.
[email protected]
One more thing:
This is what i have changed in lwipconf.h file in comparison to the original one from the example:
This is because of lwip 1.4.1 sanity check complaint.
Index: lwipopts.h
--- lwipopts.h (revision 4948)
+++ lwipopts.h (working copy)
@@ -943,7 +943,7 @@
* TCP_SND_BUF: TCP sender buffer space (bytes).
#ifndef TCP_SND_BUF
-#define TCP_SND_BUF 256
+#define TCP_SND_BUF 2048
Suggestion: modify lwipthread.c and change the link status polling interval (which is 5s by default). Set it to 3s, for example, and see if the problem you're experiencing varies its periodicity. If it does, it means that either the link status check code is broken for your PHY or that your design has some hardware problem that makes your PHY bring the link down every time it is polled.
At least you'll narrow your debugging.
Forgot. This is the code you need to modify:
/* Setup event sources.*/
evtInit(&evt, S2ST(5));
evtStart(&evt);
Change the '5'.
evtStart(&evt);
Change the '5'.
[email protected]
HI iggarpe,
Thanks for your help!
Changing this value makes a difference!
The freeze time is a multiply of the link status polling interval.
When i set it to 1 freezes occur more often (each 3-6s) but ware shorter 1-4s.
When i set it to 10 freezes occurs each 30-40s but ware taking 10s or 20s.
How come?
What now?
Greetings,
Piotr Klimczak
How come?
What now?
Greetings,
Piotr Klimczak
Not sure how to proceed, the polling of PHY never created problems in the past including DP83848.
Could it be a clock quality issue? how are you clocking your PHY?
About lwIP 1.4.1, I will try to integrate it during vacations. That for fixing that setting.
[email protected]
I have done some investigation.
It fails here:
The value of BMSR is 25088 which in binary is: 110001000000000
Values for BMSR are:
So 110001000000000 means:
#define BMSR_100HALF 0x2000 /**< Can do 100mbps, half-duplex. */
#define BMSR_100FULL 0x4000 /**< Can do 100mbps, full-duplex. */
But there is a problem with 9th bit- in docs it is said that it is always 0 as it is reserved bit.
Should I start thinking about buying a new PHY?
Greetings
Piotr
It fails here:
bool_t mac_lld_poll_link_status(MACDriver *macp) {
uint32_t maccr, bmsr, bmcr;
maccr = ETH->MACCR;
/* PHY CR and SR registers read.*/
(void)mii_read(macp, MII_BMSR);
bmsr = mii_read(macp, MII_BMSR);
bmcr = mii_read(macp, MII_BMCR);
/* Check on auto-negotiation mode.*/
if (bmcr & BMCR_ANENABLE) {
uint32_t lpa;
/* Auto-negotiation must be finished without faults and link established.*/
if ((bmsr & (BMSR_LSTATUS | BMSR_RFAULT | BMSR_ANEGCOMPLETE)) !=
(BMSR_LSTATUS | BMSR_ANEGCOMPLETE))
return macp->link_up = FALSE; ///////////////////////////HERE
#define BMSR_ERCAP 0x0001 /**< Ext-reg capability. */
#define BMSR_JCD 0x0002 /**< Jabber detected. */
#define BMSR_LSTATUS 0x0004 /**< Link status. */
#define BMSR_ANEGCAPABLE 0x0008 /**< Able to do auto-negotiation. */
#define BMSR_RFAULT 0x0010 /**< Remote fault detected. */
#define BMSR_ANEGCOMPLETE 0x0020 /**< Auto-negotiation complete. */
#define BMSR_MFPRESUPPCAP 0x0040 /**< Able to suppress preamble. */
#define BMSR_RESV 0x0780 /**< Unused. */
#define BMSR_10HALF 0x0800 /**< Can do 10mbps, half-duplex. */
#define BMSR_10FULL 0x1000 /**< Can do 10mbps, full-duplex. */
#define BMSR_100BASE4 0x8000 /**< Can do 100mbps, 4k packets. */
Greetings
Piotr
[email protected]
Accoring to clocking, question- everything works on defaults just like in LWIP demo example. I was trying to change as little as possible to eliminate possible failure causes- which is me and my code
. I just wanted to be sure that that it is not my fault
It has a 50MHz oscillator onboard.
According to my previous post, where i have written that i am receiving a value on reserved bmsr bit, there is a small chance that it occurs because of clocks- i hope. Otherwise I have to buy another one
Thanks in advance.
Thanks in advance.
