Oooh, that's good to know. Thanks!
The GCC 4.7.1 topic
Re: The GCC 4.7.1 topic
Just performed a comparison, using the ChibiOS default settings (and no libraries involved) the version 4.7.3 seems to produce slightly more compact but slower code. Attached there are the test reports for both executed on an STM32F407@168MHz.
Version 4.6.2:
Version 4.7.3:
Version 4.6.2:
>>> 34.808 byte
--- Test Case 11.1 (Benchmark, messages #1)
--- Score : 752724 msgs/S, 1505448 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.2 (Benchmark, messages #2)
--- Score : 617124 msgs/S, 1234248 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.3 (Benchmark, messages #3)
--- Score : 617119 msgs/S, 1234238 ctxswc/S
--- Result: SUCCESS
--- Score : 2528968 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.5 (Benchmark, threads, full cycle)
--- Score : 446437 threads/S
--- Result: SUCCESS
--- Test Case 11.6 (Benchmark, threads, create only)
--- Score : 631052 threads/S
--- Result: SUCCESS
--- Test Case 11.7 (Benchmark, mass reschedule, 5 threads)
--- Score : 192717 reschedules/S, 1156302 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.8 (Benchmark, round robin context switching)
--- Score : 1356420 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.9 (Benchmark, I/O Queues throughput)
--- Score : 1804932 bytes/S
--- Result: SUCCESS
--- Test Case 11.10 (Benchmark, virtual timers set/reset)
--- Score : 2180000 timers/S
--- Result: SUCCESS
--- Test Case 11.11 (Benchmark, semaphores wait/signal)
--- Score : 2685732 wait+signal/S
--- Result: SUCCESS
--- Test Case 11.12 (Benchmark, mutexes lock/unlock)
--- Score : 1886044 lock+unlock/S
--- Result: SUCCESS
Version 4.7.3:
>>> 34.504 byte
--- Score : 749363 msgs/S, 1498726 ctxswc/S
--- Result: SUCCESS
--- Score : 608179 msgs/S, 1216358 ctxswc/S
--- Result: SUCCESS
--- Score : 608175 msgs/S, 1216350 ctxswc/S
--- Result: SUCCESS
--- Score : 2510064 ctxswc/S
--- Result: SUCCESS
--- Score : 440577 threads/S
--- Result: SUCCESS
--- Score : 624014 threads/S
--- Result: SUCCESS
--- Score : 190529 reschedules/S, 1143174 ctxswc/S
--- Result: SUCCESS
--- Score : 1350960 ctxswc/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 2643424 wait+signal/S
--- Result: SUCCESS
--- Score : 1844600 lock+unlock/S
--- Result: SUCCESS
