STM32F103 ICU not starting keeping the line low
[email protected]
Post by [email protected] »
I have bought very basic board with STM32F103C8T6 uC.
I am trying to make the icu to work w/o success.
The ICU seems not to start as the line is low after starting and enabling the ICU.
Very similar code works well on STM32F4 board.
   DHT_icucfg.mode = ICU_INPUT_ACTIVE_HIGH;
   DHT_icucfg.frequency = DHT_ICU_FREQ;
   DHT_icucfg.width_cb = DHT_icuwidthcb;
   DHT_icucfg.period_cb = DHT_icuperiodcb;
   DHT_icucfg.overflow_cb = NULL;
   DHT_icucfg.channel = ICU_CHANNEL_1;
   DHT1122_data data;
   // REQUEST SAMPLE
   palSetPadMode(GPIOB, 6, PAL_MODE_OUTPUT_OPENDRAIN);
   palWritePad(GPIOB, 6, PAL_LOW);
   chThdSleepMilliseconds(20);
   palSetPadMode(GPIOB, 6, PAL_MODE_STM32_ALTERNATE_PUSHPULL);
   icuStart(&ICUD4, &DHT_icucfg);
   icuEnable(&ICUD4);
The code suppose to communicate with DHT22 sensor.
The B6 alternate function is default I2C1_SCL/TIM4_CH1.
I am not using I2C.
As I said before, the B6 line is low no matter to ICU_INPUT_ACTIVE_HIGH.
Should I do any splecial remaping or sth.?
Thanks in advance.
Greetings
Piotr Klimczak
Re: STM32F103 ICU not starting keeping the line low
If GPIOB 6 is supposed to be an ICU input then you should program it as input, not output.
[email protected]
Hi Giovanni!
Thanks for the answer.
The DHT22 needs a little trick to start transmittion.
It needs the line to be set HIGH to LOW for 20ms then back to HIGH.
HIGH to LOW is done by:
Then after 20ms:
   icuEnable(&ICUD4);
So the line is set as INPUT as I believe. Am I right?
Same code works on STM32F4, so what is wrong?
Please note that I have tried different TIMs, Channels, lines etc.
Thanks in advance!
Piotr
[email protected]
I have forgotten to say- I am using latest trunk.
Piotr
The F4 has a different GPIO, the F1 requires that the alternate inputs to be normal inputs but I think that also output open drain should work. Just keep it PAL_MODE_OUTPUT_OPENDRAIN set to high.
[email protected]
Thanks a lot Giovanni!
As always you ware right! :)
Everything works well now!
BTW. Happy new year!
Greetings,
Piotr
