Hi all,
In my project, I use both STM32L152RB and STM32W108. I use ChibiOS for STM32L152RB, because ChibiOS doesn't support STM32W108 so I use ContikiOS for STM32W108. But I have some big problems:
1. I don't know which IDE is used for ContikiOS?
2. Can I import ContikiOS to Keil (like ChibiOS)?
Please help me.
Many thanks.
ChibiOS and ContikiOS
Re: ChibiOS and ContikiOS
lenh_tap_ket wrote:1. I don't know which IDE is used for ContikiOS?
In case of you mean ChibiOS here (since I guess you're already using ContikiOS successfully) -> You don't need to use any IDE to use ChibiOS if you don't want to. ChibiOS is completely makefile driven which makes development without any IDE simple.
However, there's a subproject called ChibiStudio. It's basically a ready to use eclipse environement. You might want to check it's subforum.
There's also a tutorial showing how to use ChibiOS within Keil.
If you didn't mean ChibiOS up there, I guess you're in the wrong forum here.
If you need info about ContikiOS probably you should ask in their mailing list, personally I never had a chance to try it.
