SPI configuration in STM32f4 discovery demo
Faisal Mehmood
Post by Faisal Mehmood »
Hey all
I have some problem with the following line of spi1cfg portion of STM32F4 discovery demo code:
SPI_CR1_BR_0 | SPI_CR1_BR_1 | SPI_CR1_CPOL | SPI_CR1_CPHA
I went through the STMF4xx reference manual and also read the stm32f4xx.h file in hal folder of OS directory. I can't understand how the configuration bits of the SPICONFIG structure determine the 5.25Mhz baudrate of SPI1 while according to the reference manual, those settings mean:
SPI_CR1_BR_0 = 1
SPI_CR1_BR_1 = 1 - - - - - - - } BR[2:0] = 011 => Baudrate = fclk/256 = 168Mega/256 = 656.2 KHz
SPI_CR1_BR_2 = 0
may be i misunderstood the bit configurations :roll:
Kindly tell me where the problem is
Re: SPI configuration in STM32f4 discovery demo
Where exactly do you get the 5.25MHz from? Is that written somewhere? Also, I just checked the F4-Discovery demo code and no SPI1 is used? Only SPI2 is used with the max. speed.
Faisal Mehmood
guess both spi1 nd spi2 are being used
5.25Mhz is stated in the comments:
 * SPI1 configuration structure.
 * Speed 5.25MHz, CPHA=1, CPOL=1, 8bits frames, MSb transmitted first.
 * The slave select line is the pin GPIOE_CS_SPI on the port GPIOE.
static const SPIConfig spi1cfg = {
  NULL,
  /* HW dependent part.*/
  GPIOE,
  GPIOE_CS_SPI,
 * SPI2 configuration structure.
 * Speed 21MHz, CPHA=0, CPOL=0, 16bits frames, MSb transmitted first.
 * The slave select line is the pin 12 on the port GPIOA.
static const SPIConfig spi2cfg = {
  spicb,
  GPIOB,
  12,
  SPI_CR1_DFF
etmatrix
Post by etmatrix »
Faisal Mehmood wrote:may be i misunderstood the bit configurations :roll:
For configure speed in SPI I use the follow define
// Peripherial Clock 42MHz SPI2 SPI3
// Peripherial Clock 84MHz SPI1                                SPI1        SPI2/3
#define SPI_BaudRatePrescaler_2         ((uint16_t)0x0000) //  42 MHz      21 MHZ
#define SPI_BaudRatePrescaler_4         ((uint16_t)0x0008) //  21 MHz      10.5 MHz
#define SPI_BaudRatePrescaler_8         ((uint16_t)0x0010) //  10.5 MHz    5.25 MHz
#define SPI_BaudRatePrescaler_16        ((uint16_t)0x0018) //  5.25 MHz    2.626 MHz
#define SPI_BaudRatePrescaler_32        ((uint16_t)0x0020) //  2.626 MHz   1.3125 MHz
#define SPI_BaudRatePrescaler_64        ((uint16_t)0x0028) //  1.3125 MHz  656.25 KHz
#define SPI_BaudRatePrescaler_128       ((uint16_t)0x0030) //  656.25 KHz  328.125 KHz
#define SPI_BaudRatePrescaler_256       ((uint16_t)0x0038) //  328.125 KHz 164.06 KHz
static const SPIConfig spicfg = { NULL, TP_CS_PORT, TP_CS_PIN, SPI_BaudRatePrescaler_32 };
I tried to understand the reference manual, but for me is not explained well in that section. So I have found these defines in ST Library and I use always these for my projects.
Faisal Mehmood
Thanx for the replies guys I guess I now know what the problems were:
1) I assumed SPI1 peripheral clock to be 168Mhz while actually its 84Mhz
2) BR[2:0] = 011 means the peripheral clock will be divided by 16, not 256 as i thought previously... clock is divided by 256 when BR[2:0] = 111
Thanx again guys!
Better add similar definitions directly to the SPI driver. Sorry for being late but I was in travel and the mobile worked intermittently.
I fully agree that your settings would result in a prescaler of 16. Sorry that I didn't tell you that but I didn't clearly look at your code, since I am still searching the part where the STM32F407 Discovery demo does use SPI1...
I would have loved to help here but I was too confused about where SPI1 is in the STM32F4 Discovery demo code? Can anybody please lead me to the light? :D
Faisal Mehmood
@ Tectu you might have downloaded another file :)
here in the main.c file of STM32F4 Discovery demo code:
    ChibiOS/RT - Copyright (C) 2006,2007,2008,2009,2010,
                 2011,2012 Giovanni Di Sirio.
    This file is part of ChibiOS/RT.
    ChibiOS/RT is free software; you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation; either version 3 of the License, or
    (at your option) any later version.
    ChibiOS/RT is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
    A special exception to the GPL can be applied should you wish to distribute
    a combined work that includes ChibiOS/RT, without being obliged to provide
    the source code for any proprietary components. See the file exception.txt
    for full details of how and when the exception can be applied.
#include "ch.h"
#include "hal.h"
#include "test.h"
#include "lis302dl.h"
#include "chprintf.h"
static void pwmpcb(PWMDriver *pwmp);
static void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n);
static void spicb(SPIDriver *spip);
/* Total number of channels to be sampled by a single ADC operation.*/
#define ADC_GRP1_NUM_CHANNELS   2
/* Depth of the conversion buffer, channels are sampled four times each.*/
#define ADC_GRP1_BUF_DEPTH      4
 * ADC samples buffer.
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
 * ADC conversion group.
 * Mode:        Linear buffer, 4 samples of 2 channels, SW triggered.
 * Channels:    IN11   (48 cycles sample time)
 *              Sensor (192 cycles sample time)
  FALSE,
  ADC_GRP1_NUM_CHANNELS,
  adccb,
  NULL,
  0,
  ADC_CR2_SWSTART,
  ADC_SMPR1_SMP_AN11(ADC_SAMPLE_56) | ADC_SMPR1_SMP_SENSOR(ADC_SAMPLE_144),
  0,
  ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),
  0,
  ADC_SQR3_SQ2_N(ADC_CHANNEL_IN11) | ADC_SQR3_SQ1_N(ADC_CHANNEL_SENSOR)
 * PWM configuration structure.
 * Cyclic callback enabled, channels 1 and 4 enabled without callbacks,
 * the active state is a logic one.
static PWMConfig pwmcfg = {
  10000,                                    /* 10kHz PWM clock frequency.   */
  10000,                                    /* PWM period 1S (in ticks).    */
  pwmpcb,
    {PWM_OUTPUT_ACTIVE_HIGH, NULL},
    {PWM_OUTPUT_DISABLED, NULL},
  0
  NULL,
  GPIOE,
  GPIOE_CS_SPI,
  spicb,
  GPIOB,
  12,
  SPI_CR1_DFF
 * PWM cyclic callback.
 * A new ADC conversion is started.
static void pwmpcb(PWMDriver *pwmp) {
  (void)pwmp;
  /* Starts an asynchronous ADC conversion operation, the conversion
     will be executed in parallel to the current PWM cycle and will
     terminate before the next PWM cycle.*/
  chSysLockFromIsr();
  adcStartConversionI(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
  chSysUnlockFromIsr();
 * ADC end conversion callback.
 * The PWM channels are reprogrammed using the latest ADC samples.
 * The latest samples are transmitted into a single SPI transaction.
void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
  (void) buffer; (void) n;
  /* Note, only in the ADC_COMPLETE state because the ADC driver fires an
     intermediate callback when the buffer is half full.*/
  if (adcp->state == ADC_COMPLETE) {
    adcsample_t avg_ch1, avg_ch2;
    /* Calculates the average values from the ADC samples.*/
    avg_ch1 = (samples[0] + samples[2] + samples[4] + samples[6]) / 4;
    avg_ch2 = (samples[1] + samples[3] + samples[5] + samples[7]) / 4;
    chSysLockFromIsr();
    /* Changes the channels pulse width, the change will be effective
       starting from the next cycle.*/
    pwmEnableChannelI(&PWMD4, 0, PWM_FRACTION_TO_WIDTH(&PWMD4, 4096, avg_ch1));
    pwmEnableChannelI(&PWMD4, 3, PWM_FRACTION_TO_WIDTH(&PWMD4, 4096, avg_ch2));
    /* SPI slave selection and transmission start.*/
    spiSelectI(&SPID2);
    spiStartSendI(&SPID2, ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH, samples);
 * SPI end transfer callback.
static void spicb(SPIDriver *spip) {
  /* On transfer end just releases the slave select line.*/
  chSysLockFromIsr();
  spiUnselectI(spip);
 * This is a periodic thread that does absolutely nothing except flashing
 * a LED.
void static msg_t Thread1(void *arg) {
  (void)arg;
  while (TRUE) {
    palSetPad(GPIOD, GPIOD_LED3);       /* Orange.  */
    chThdSleepMilliseconds(500);
    palClearPad(GPIOD, GPIOD_LED3);     /* Orange.  */
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
   * Activates the serial driver 2 using the driver default configuration.
   * PA2(TX) and PA3(RX) are routed to USART2.
  sdStart(&SD2, NULL);
  palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
  palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));
   * If the user button is pressed after the reset then the test suite is
   * executed immediately before activating the various device drivers in
   * order to not alter the benchmark scores.
  if (palReadPad(GPIOA, GPIOA_BUTTON))
    TestThread(&SD2);
   * Initializes the SPI driver 2. The SPI2 signals are routed as follow:
   * PB12 - NSS.
   * PB13 - SCK.
   * PB14 - MISO.
   * PB15 - MOSI.
  spiStart(&SPID2, &spi2cfg);
  palSetPad(GPIOB, 12);
  palSetPadMode(GPIOB, 12, PAL_MODE_OUTPUT_PUSHPULL |
                           PAL_STM32_OSPEED_HIGHEST);           /* NSS.     */
  palSetPadMode(GPIOB, 13, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);           /* SCK.     */
  palSetPadMode(GPIOB, 14, PAL_MODE_ALTERNATE(5));              /* MISO.    */
  palSetPadMode(GPIOB, 15, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);           /* MOSI.    */
   * Initializes the ADC driver 1 and enable the thermal sensor.
   * The pin PC0 on the port GPIOC is programmed as analog input.
  adcStart(&ADCD1, NULL);
  adcSTM32EnableTSVREFE();
  palSetPadMode(GPIOC, 1, PAL_MODE_INPUT_ANALOG);
   * Initializes the PWM driver 4, routes the TIM4 outputs to the board LEDs.
  pwmStart(&PWMD4, &pwmcfg);
  palSetPadMode(GPIOD, GPIOD_LED4, PAL_MODE_ALTERNATE(2));  /* Green.   */
  palSetPadMode(GPIOD, GPIOD_LED6, PAL_MODE_ALTERNATE(2));  /* Blue.    */
   * Creates the example thread.
   * Initializes the SPI driver 1 in order to access the MEMS. The signals
   * are initialized in the board file.
   * Several LIS302DL registers are then initialized.
  spiStart(&SPID1, &spi1cfg);
  lis302dlWriteRegister(&SPID1, LIS302DL_CTRL_REG1, 0x43);
  lis302dlWriteRegister(&SPID1, LIS302DL_CTRL_REG2, 0x00);
  lis302dlWriteRegister(&SPID1, LIS302DL_CTRL_REG3, 0x00);
   * sleeping in a loop and check the button state, when the button is
   * pressed the test procedure is launched with output on the serial
   * driver 2.
  while (TRUE) {
    int8_t x, y, z;
      TestThread(&SD2);
    x = (int8_t)lis302dlReadRegister(&SPID1, LIS302DL_OUTX);
    y = (int8_t)lis302dlReadRegister(&SPID1, LIS302DL_OUTY);
    z = (int8_t)lis302dlReadRegister(&SPID1, LIS302DL_OUTZ);
    chprintf((BaseChannel *)&SD2, "%d, %d, %d\r\n", x, y, z);
You should have checked out the link I have posted... This is the STM32F407 Discovery code. It looks like you where talking about the STM32F407 MEMS Discovery code all the time...
Well, never mind then.
