ST-Link V2 on Linux/OSX/Windows
DeusExMachina
Has thanked: 3 times
Been thanked: 3 times
Re: ST-Link V2 on Linux/OSX/Windows
Post by DeusExMachina »
debugging freeses in asm code
void _port_thread_start(void) {
  chSysUnlock();
  asm volatile ("mov     r0, r5                                 \n\t"
                "blx     r4                                     \n\t"
                "bl      chThdExit");
Tectu, could you share your old st-util code for me?
Sorry, I just took a look and I don't have the code / binary / repo anymore. Also, I couldn't find it in my backups since I did rebuild my backup server a month ago and I didn't move stuff :P
Just try the repo state from let's say July. You can directly download a zip file from github.com.
I remember that there were some gdb version issues. The newest GDB versions didn't work properly. But I'm not sure if this is still the case. Also, I am 100% sure that an error like yours didn't occur.
DeusExMachina
thank you, I'll try to rollback using git
You could also try to explain to me why you want to use texane instead of OpenOCD? STLink are both, v1 and v2 supported. Also, mabl integrated ChibiOS/RT debugging support into OpenOCD (git version!).
DeusExMachina
really :) it's time to move, I think...
There you go :)
Well, the only thing I can tell you is, that you won't regret it afterwards. OpenOCD works very stable here and again, there's ChibiOS debugging support built-in.
DeusExMachina
I download last openocd, but I can't get it working... It connects target and adapter, but I cant flash MCU, and many examples from internet don't work... For example "monitor" commands is deprecated... When I use load i get error "cant load in exec mode". Halt commands (monitor halt, soft-halt) don't work :( I need a good instructions to set up openocd :( The last one...
Just to get this right... You can start openocd and connect to the target successfully, right? So, you do open arm-none-eabi-gdb afterwards, right? Then you connect to the openocd server?
Also this.
DeusExMachina
Tectu wrote:Just to get this right... You can start openocd and connect to the target successfully, right? So, you do open arm-none-eabi-gdb afterwards, right? Then you connect to the openocd server?
yes, openocd starts (but successfully connect to MCU only on the second run, first run fails). arm-none-eabi-gdb connects to 4444 port and they become to speak :) I load symbols, but image doesn’t load, because of "cant load in exec mode" error.
Tectu wrote:Also this.
Excellent article, I’ll try it ASAP :)
Try to follow the guide, you should go with 3333 instead of 4444 default port. 4444 is telnet.
Feel free to extend the guide to your needs. I never really came to finish the actual debugging part.
