Memory Pool
carnecro
Memory Pool
Post by carnecro »
I have following issue
Structure:
typedef struct {
        uint8_t counter ;
        uint8_t buff[MAX_LENGTH] ;
} MSG_BUFF ;
Memory Pool:
MemoryPool msg_pool;
static MSG_BUFF msg_pool_buffer[MAX_MESSAGES] __attribute__((aligned(sizeof(stkalign_t)))) ;
Initialisation:
chPoolInit(&msg_pool, sizeof(MSG_BUFF), NULL );
for (i = 0; i < (MAX_MESSAGES); i++) {
     chPoolFree(&msg_pool, &msg_pool_buffer[i]);
Looks like chPoolFree() overwrites parts of the structure memory. I initialised the structure with data and after return from chPoolFree() some of structure bytes has been modified. Is it as expected or do I anything wrong (version 2.5.1)
Re: Memory Pool
The memory pools manager uses the first sizeof(void *) bytes of the object to store a pointer to the next object when the object is in the pool. You can't have pools of pre-initialized objects unless you put a reserved pointer as first field of the structure.
carnecro
Re: Memory Pool
Post by carnecro »
From the documentation it's not obvious, thank you for the hint. In my case the solution was
typedef struct {
        struct pool_header *phdr;
        uint8_t counter ;
} MSG_BUFF ;
in this post http://forum.chibios.org/phpbb/viewtopic.php?f=2&t=722&p=7288&hilit=memory+pool#p7288 is another example of the right structure.
skute
Re: Memory Pool
Post by skute »
I use a wrapper around all of the ChibiOS functions. In the case of MemoryPools, I also have some helper macros/functions to ensure the correct alignment and pool size.
See below (the usage example explains how I use it), note that some of the defines are internal to specific files, others are exported in headers which is why some of the macro's look to have duplicated code:
// alignment must be a power of 2
#define ALIGN_UP(val, alignment) (((val) + ((alignment) - 1)) & ~((alignment) - 1)
#define MAX(a, b)        (((a) > (b)) ? (a) : (b)
#define OS_POOL_DATA_SIZE(elementSize, numElements) \
    (ALIGN_UP(MAX(elementSize, sizeof(struct pool_header)), sizeof(uintptr_t)) * numElements)
#define POOL_ENTRY_SIZE(entrySize) \
    (ALIGN_UP(MAX(entrySize, sizeof(struct pool_header)), sizeof(uintptr_t)))
#define MAX_POOL_ENTRIES(poolSize, entrySize) \
    (poolSize / POOL_ENTRY_SIZE(entrySize))
#define OS_CHECK_ARG(arg) { \
        assert(NULL != arg); \
        if (NULL == arg) { \
            return OS_ERROR_BAD_ARG; \
typedef MemoryPool      OS_MemPool_t;
typedef uint8_t         OS_MemPoolData_t;
 * usage:
 * struct poolElement
 *      uint8_t code;
 *      uint16_t somethingElse;
 * #define NUM_ELEMENTS (16u)
 * uint32_t numElements = NUM_ELEMENTS;
 * OS_MemPool_t pool;
 * OS_MemPoolData_t poolData[OS_POOL_DATA_SIZE(sizeof(struct poolElement), NUM_ELEMENTS)];
 * OS_MemPoolInit(&pool, poolData, sizeof(poolData), sizeof(struct poolElement), &numElements);
OS_Result_t
OS_MemPoolInit(OS_MemPool_t *pMemPool,
               OS_MemPoolData_t *pMemPoolData,
               uint32_t poolDataSize,
               uint32_t poolObjectSize,
               uint32_t *numPoolObjects)
    size_t numEntries;
    OS_CHECK_ARG(pMemPool);
    OS_CHECK_ARG(pMemPoolData);
    OS_CHECK_ARG(numPoolObjects);
    assert(*numPoolObjects == MAX_POOL_ENTRIES(poolDataSize, poolObjectSize));
    numEntries = MAX_POOL_ENTRIES(poolDataSize, poolObjectSize);
    chPoolInit(pMemPool, POOL_ENTRY_SIZE(poolObjectSize), NULL);
    chPoolLoadArray(pMemPool, pMemPoolData, numEntries);
    *numPoolObjects = (uint32_t)numEntries;
    return OS_SUCCESS;
With this, you don't need to add the struct pool_header *phdr to your MSG_BUFF.
