This will print "test....\r\n" to the SD2 driver once and then it won't do anything anymore in that thread, where the following one will print it over and over again:
Of course your right i mean these are same in printing the whole of the string but one of them once and the other in a loop. the problem is to compare a delay with endless loop in this situation. Thanks for your attention . Regards
So your problem is still not solved, right? I sadly forgot to test it on my hardware and right know I'm again somewhere where I don't have any. I will try this tomorrow evening, but as Giovanni already said, this should work (as in, no characters get lost).
I expect the reason this doesn't work is because the //while(TRUE). This function will exit and return to the default clibrary atexit() function or __exit or something along those lines. Either uncomment the //while(TRUE) or add a longer sleep, perhaps 100ms.
Tectu wrote:The while(TRUE) does for sure not cause the problem unless a memory stack issue as Giovanni now mentioned two times, please check this!
It most certainly can. For example, if the baud rate is 9600, it will take 1ms per character to exit the serial data register. In this case, the thread will wake up, and exit the main() function before the complete string has been transmitted out the serial port. If this were to happen, you can probably kiss your stack goodbye, and the OS is no longer running, etc.
I agree, that's why I wrote "unless a stack issue". I just meant that the while(TRUE) itself doesn't do anything to the system or the HAL itself that would do anything bad. And most likely, that's why Giovanni mentioned to check the stack stuff as well.
Tectu wrote:I agree, that's why I wrote "unless a stack issue". I just meant that the while(TRUE) itself doesn't do anything to the system or the HAL itself that would do anything bad. And most likely, that's why Giovanni mentioned to check the stack stuff as well.
If the program exits main(), there is no stack issue; there is no stack, there is no system, no hal, it is dead. This is why adding a while(1) after the print works or putting the print in a while(1) loop works. The code is functioning as written and exiting main(). If the uart driver (unbuffered) was used instead of the serial driver (buffered), you would see the complete print.
