Tectu wrote:Good to hear that you could "solve" your issue
Thanks to your initial advice I also got the remaining issues solved. It turned out the PCB designer forgot to connect the PHY oscillator with the supply plane. No clock, no working PHY
The last thing wrong was the default state of the GPIO output connected with the PHY reset line.
Now my custom eval board happly blinks two LEDs and wait for the connector mezzanine to be finished, so that I can connect ETH and Display.
