Creating new project in ChibiStudio. Step-by-step guide.
jscott
Re: Creating new project in ChibiStudio. Step-by-step guide.
Post by jscott »
Perhaps I did not make myself clear.
This is from the unmodified demo program. No changes were made.
-John Scott
Sorry, I misunderstood, apparently mcuconf.h got corrupted in that demo somehow...
You can replace it by taking the file from the trunk, I will open a ticket for 2.6.3.
Ramazzukk
Post by Ramazzukk »
Hi everyone
I try to do the same, copy an existing project, change its name and reimport into ChibiStudio.
1. Copy/Paste the projectfolder on Windows (New Name STM32F4DISCOVERY_NEWPROJECT)
2. Change the Name of the project in the File .project under <name>STM32F4DISCOVERY_NEWPROJECT</name>
3. Import it in Eclipse under File/Import/Existing Projects into Workspace
4. Add it to a working set
5. Clean / Build works, but eclipse gives me an error.
Sometimes it works, sometimes not. Is there anywhere a wrong setting or path or something?
Thank for any help in advance!
Try to just CTRL-C CTRL-V a project, it prompts for a new name and it always works for me.
Ramazzukk
Post by Ramazzukk »
Same problem, very strange. I run it on W7/64, Java 32bit.
I'l try it on a WXP-Machine later.. But what can that be?
org.eclipse.core.runtime.CoreException: Internal error building project demo6 configuration Default
   at org.eclipse.cdt.managedbuilder.core.ExternalBuildRunner.invokeExternalBuild(ExternalBuildRunner.java:142)
   at org.eclipse.cdt.managedbuilder.core.ExternalBuildRunner.invokeBuild(ExternalBuildRunner.java:72)
   at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performExternalClean(CommonBuilder.java:1149)
   at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.clean(CommonBuilder.java:1078)
   at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.clean(CommonBuilder.java:1046)
   at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:730)
   at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
   at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
   at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
   at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
   at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:513)
   at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:432)
   at org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:305)
   at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
   at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
java.lang.NullPointerException
   at org.eclipse.cdt.core.resources.RefreshScopeManager.initializeConfigMap(RefreshScopeManager.java:523)
   at org.eclipse.cdt.core.resources.RefreshScopeManager.getConfigurationToResourcesMap(RefreshScopeManager.java:305)
   at org.eclipse.cdt.core.resources.RefreshScopeManager.getResourcesToExclusionsMap(RefreshScopeManager.java:283)
   at org.eclipse.cdt.core.resources.RefreshScopeManager.getResourcesToRefresh(RefreshScopeManager.java:395)
   at org.eclipse.cdt.core.resources.RefreshScopeManager.shouldResourceBeRefreshed(RefreshScopeManager.java:773)
   at org.eclipse.cdt.core.resources.RefreshScopeManager$2.refreshResources(RefreshScopeManager.java:350)
   at org.eclipse.cdt.core.resources.RefreshScopeManager$2.run(RefreshScopeManager.java:374)
   at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
   at org.eclipse.cdt.internal.core.BuildRunnerHelper.refreshProject(BuildRunnerHelper.java:334)
   at org.eclipse.cdt.managedbuilder.core.ExternalBuildRunner.invokeExternalBuild(ExternalBuildRunner.java:133)
Ramazzukk
Post by Ramazzukk »
I tried it on a Windows XP (fresh installed). Same error.
I tried different demo-Projects. It is only the ARMCM4-STM32F407-DISCOVERY-Project making trouble..
I haven't tried every demo-project, but several are working fine copied the way you mentioned, including the MEMS-Demo.
Strange...
