Page 2 of 2
Re: porting ChibiOS to STM32373C-EVAL
Posted: Fri Nov 22, 2013 4:43 pm
by madokapeng
Giovanni wrote:Hi,
Look at the Makefiles of the F3 demos and find the "include" (there are several of them), those .mk files contain all paths you have to use in your project.
Thanks for supporting
I will give it a shot.
Posted: Fri Nov 22, 2013 10:42 pm
by madokapeng
Giovanni wrote:Hi,
I am confusing about RVCT.
I looked at F3 demos, the include files are in os\ports\GCC folder instead of os\ports\RVCT. can I specify os\ports\GCC in Keil IDE environment.
My question is novice, I am really new to RTOS.
Thank you
Posted: Fri Nov 22, 2013 10:48 pm
Of course the only paths you have to change are those containing GCC and point them to the RVCT directories.
This reminds me that you have to create the vector.s file for the STM32F3 because there is not one done, you could use the one of the F4 and remove the excess vectors. Put the files into .\os\ports\RVCT\ARMCMx\STM32F3xx and point your project there.
Posted: Fri Nov 22, 2013 11:05 pm
by madokapeng
Giovanni wrote:Of course the only paths you have to change are those containing GCC and point them to the RVCT directories.
How do I know what are the excess vectors by looking at vector.s of F4?
Is there a way to tell the vector difference between F4 and F3?
Thank you
Posted: Fri Nov 22, 2013 11:27 pm
by madokapeng
ok, got it
look at datasheet
Thanks for the hints
Posted: Sat Nov 23, 2013 9:55 am
Not the datasheet, there is a section on the Reference Manual. You may also look at vectors.c for GCC :)
Posted: Wed Nov 27, 2013 5:15 am
by madokapeng
Giovanni wrote:Not the datasheet, there is a section on the Reference Manual. You may also look at vectors.c for GCC :)
After I compiled, it comes following errors. What could be causing those errors?
I followed exact what we discussed before
Rebuild target 'Target 1'
compiling main.c...
.\os\hal\platforms\STM32\GPIOv1\pal_lld.h(122): error: #20: identifier "GPIO_TypeDef" is undefined
typedef GPIO_TypeDef * ioportid_t;
main.c(21): error: #20: identifier "GPIO_TypeDef" is undefined
palSetPad(GPIOC, GPIOC_LED1);
main.c(21): error: #29: expected an expression
main.c(23): error: #29: expected an expression
palClearPad(GPIOC, GPIOC_LED2);
main.c(34): error: #20: identifier "GPIO_TypeDef" is undefined
main.c(34): error: #29: expected an expression
main.c(36): error: #29: expected an expression
main.c: 0 warnings, 7 errors
compiling chcond.c...
compiling chdebug.c...
compiling chdynamic.c...
compiling chevents.c...
compiling chheap.c...
compiling chlists.c...
compiling chmboxes.c...
compiling chmemcore.c...
compiling chmempools.c...
compiling chmsg.c...
compiling chmtx.c...
compiling chqueues.c...
compiling chregistry.c...
compiling chschd.c...
compiling chsem.c...
compiling chsys.c...
compiling chthreads.c...
compiling chvt.c...
compiling adc.c...
os\hal\src\adc.c: 0 warnings, 1 error
compiling hal.c...
os\hal\src\hal.c: 0 warnings, 1 error
compiling pal.c...
os\hal\src\pal.c(82): error: #132: expression must have pointer-to-struct-or-union type
return palReadGroup(bus->portid, bus->mask, bus->offset);
os\hal\src\pal.c(108): error: #132: expression must have pointer-to-struct-or-union type
palWriteGroup(bus->portid, bus->mask, bus->offset, bits);
os\hal\src\pal.c: 0 warnings, 3 errors
compiling pwm.c...
os\hal\src\pwm.c: 0 warnings, 1 error
compiling serial.c...
os\hal\src\serial.c: 0 warnings, 1 error
compiling spi.c...
os\hal\src\spi.c: 0 warnings, 1 error
compiling hal_lld.c...
os\hal\platforms\STM32F37x\hal_lld.c: 0 warnings, 1 error
compiling stm32_dma.c...
os\hal\platforms\STM32F37x\stm32_dma.c: 0 warnings, 1 error
compiling pal_lld.c...
os\hal\platforms\STM32\GPIOv1\pal_lld.c(82): error: #20: identifier "RCC_APB2ENR_IOPAEN" is undefined
rccEnableAPB2(APB2_EN_MASK, FALSE);
os\hal\platforms\STM32\GPIOv1\pal_lld.c(82): error: #20: identifier "RCC_APB2ENR_IOPBEN" is undefined
os\hal\platforms\STM32\GPIOv1\pal_lld.c(82): error: #20: identifier "RCC_APB2ENR_IOPCEN" is undefined
os\hal\platforms\STM32\GPIOv1\pal_lld.c(82): error: #20: identifier "RCC_APB2ENR_IOPDEN" is undefined
os\hal\platforms\STM32\GPIOv1\pal_lld.c(82): error: #20: identifier "RCC_APB2ENR_IOPEEN" is undefined
os\hal\platforms\STM32\GPIOv1\pal_lld.c(82): error: #20: identifier "RCC_APB2ENR_AFIOEN" is undefined
os\hal\platforms\STM32\GPIOv1\pal_lld.c(87): error: #20: identifier "GPIO_TypeDef" is undefined
GPIOA->ODR = config->PAData.odr;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(87): error: #29: expected an expression
os\hal\platforms\STM32\GPIOv1\pal_lld.c(88): error: #29: expected an expression
GPIOA->CRH = config->PAData.crh;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(89): error: #29: expected an expression
GPIOA->CRL = config->PAData.crl;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(90): error: #29: expected an expression
GPIOB->ODR = config->PBData.odr;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(91): error: #29: expected an expression
GPIOB->CRH = config->PBData.crh;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(92): error: #29: expected an expression
GPIOB->CRL = config->PBData.crl;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(93): error: #29: expected an expression
GPIOC->ODR = config->PCData.odr;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(94): error: #29: expected an expression
GPIOC->CRH = config->PCData.crh;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(95): error: #29: expected an expression
GPIOC->CRL = config->PCData.crl;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(96): error: #29: expected an expression
GPIOD->ODR = config->PDData.odr;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(97): error: #29: expected an expression
GPIOD->CRH = config->PDData.crh;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(98): error: #29: expected an expression
GPIOD->CRL = config->PDData.crl;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(100): error: #29: expected an expression
GPIOE->ODR = config->PEData.odr;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(101): error: #29: expected an expression
GPIOE->CRH = config->PEData.crh;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(102): error: #29: expected an expression
GPIOE->CRL = config->PEData.crl;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(104): error: #29: expected an expression
GPIOF->ODR = config->PFData.odr;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(105): error: #29: expected an expression
GPIOF->CRH = config->PFData.crh;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(106): error: #29: expected an expression
GPIOF->CRL = config->PFData.crl;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(158): error: #132: expression must have pointer-to-struct-or-union type
port->BSRR = mask;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(160): error: #132: expression must have pointer-to-struct-or-union type
port->BRR = mask;
os\hal\platforms\STM32\GPIOv1\pal_lld.c(178): error: #132: expression must have pointer-to-struct-or-union type
port->CRH = (port->CRH & mh) | crh;
os\hal\platforms\STM32\GPIOv1\pal_lld.c: 0 warnings, 30 errors
compiling spi_lld.c...
os\hal\platforms\STM32\SPIv1\spi_lld.c: 0 warnings, 1 error
compiling adc_lld.c...
os\hal\platforms\STM32F37x\adc_lld.c: 0 warnings, 1 error
compiling pwm_lld.c...
os\hal\platforms\STM32\TIMv1\pwm_lld.c: 0 warnings, 1 error
compiling serial_lld.c...
os\hal\platforms\STM32\USARTv1\serial_lld.c(111): error: #136: struct "<unnamed>" has no field "SR"
u->SR = 0;
os\hal\platforms\STM32\USARTv1\serial_lld.c(112): error: #136: struct "<unnamed>" has no field "SR"
(void)u->SR; /* SR reset step 1.*/
os\hal\platforms\STM32\USARTv1\serial_lld.c(113): error: #136: struct "<unnamed>" has no field "DR"
(void)u->DR; /* SR reset step 2.*/
os\hal\platforms\STM32\USARTv1\serial_lld.c(138): error: #20: identifier "USART_SR_ORE" is undefined
if (sr & USART_SR_ORE)
os\hal\platforms\STM32\USARTv1\serial_lld.c(140): error: #20: identifier "USART_SR_PE" is undefined
if (sr & USART_SR_PE)
os\hal\platforms\STM32\USARTv1\serial_lld.c(142): error: #20: identifier "USART_SR_FE" is undefined
if (sr & USART_SR_FE)
os\hal\platforms\STM32\USARTv1\serial_lld.c(144): error: #20: identifier "USART_SR_NE" is undefined
if (sr & USART_SR_NE)
os\hal\platforms\STM32\USARTv1\serial_lld.c(159): error: #136: struct "<unnamed>" has no field "SR"
uint16_t sr = u->SR; /* SR reset step 1.*/
os\hal\platforms\STM32\USARTv1\serial_lld.c(160): error: #136: struct "<unnamed>" has no field "DR"
uint16_t dr = u->DR; /* SR reset step 2.*/
os\hal\platforms\STM32\USARTv1\serial_lld.c(163): error: #20: identifier "USART_SR_ORE" is undefined
if (sr & (USART_SR_ORE | USART_SR_NE | USART_SR_FE | USART_SR_PE))
os\hal\platforms\STM32\USARTv1\serial_lld.c(163): error: #20: identifier "USART_SR_NE" is undefined
os\hal\platforms\STM32\USARTv1\serial_lld.c(163): error: #20: identifier "USART_SR_FE" is undefined
os\hal\platforms\STM32\USARTv1\serial_lld.c(163): error: #20: identifier "USART_SR_PE" is undefined
os\hal\platforms\STM32\USARTv1\serial_lld.c(166): error: #20: identifier "USART_SR_LBD" is undefined
if (sr & USART_SR_LBD) {
os\hal\platforms\STM32\USARTv1\serial_lld.c(170): error: #136: struct "<unnamed>" has no field "SR"
u->SR &= ~USART_SR_LBD;
os\hal\platforms\STM32\USARTv1\serial_lld.c(173): error: #20: identifier "USART_SR_RXNE" is undefined
if (sr & USART_SR_RXNE) {
os\hal\platforms\STM32\USARTv1\serial_lld.c(179): error: #20: identifier "USART_SR_TXE" is undefined
if ((cr1 & USART_CR1_TXEIE) && (sr & USART_SR_TXE)) {
os\hal\platforms\STM32\USARTv1\serial_lld.c(188): error: #136: struct "<unnamed>" has no field "DR"
u->DR = b;
os\hal\platforms\STM32\USARTv1\serial_lld.c(192): error: #20: identifier "USART_SR_TC" is undefined
if (sr & USART_SR_TC) {
os\hal\platforms\STM32\USARTv1\serial_lld.c(197): error: #136: struct "<unnamed>" has no field "SR"
u->SR &= ~USART_SR_TC;
os\hal\platforms\STM32\USARTv1\serial_lld.c: 0 warnings, 21 errors
compiling chcore.c...
compiling chcore_v7m.c...
assembling chcoreasm_v7m.s...
assembling cstartup.s...
assembling vectors.s...
compiling nvic.c...
compiling board.c...
conf\board.c(28): error: #146: too many initializer values
{VAL_GPIOA_MODER, VAL_GPIOA_OTYPER, VAL_GPIOA_OSPEEDR, VAL_GPIOA_PUPDR,
conf\board.c(30): error: #146: too many initializer values
{VAL_GPIOB_MODER, VAL_GPIOB_OTYPER, VAL_GPIOB_OSPEEDR, VAL_GPIOB_PUPDR,
conf\board.c(32): error: #146: too many initializer values
{VAL_GPIOC_MODER, VAL_GPIOC_OTYPER, VAL_GPIOC_OSPEEDR, VAL_GPIOC_PUPDR,
conf\board.c(34): error: #146: too many initializer values
{VAL_GPIOD_MODER, VAL_GPIOD_OTYPER, VAL_GPIOD_OSPEEDR, VAL_GPIOD_PUPDR,
conf\board.c(36): error: #146: too many initializer values
{VAL_GPIOE_MODER, VAL_GPIOE_OTYPER, VAL_GPIOE_OSPEEDR, VAL_GPIOE_PUPDR,
conf\board.c(38): error: #146: too many initializer values
{VAL_GPIOF_MODER, VAL_GPIOF_OTYPER, VAL_GPIOF_OSPEEDR, VAL_GPIOF_PUPDR,
conf\board.c: 0 warnings, 7 errors
".\myproject.axf" - 78 Error(s), 0 Warning(s).
Target not created
Posted: Wed Nov 27, 2013 9:21 am
Probably you are missing an inclusion directory: ./os/hal/platforms/STM32F37x
