porting ChibiOS to STM32373C-EVAL
madokapeng
Post by madokapeng »
I am new to chibiOS,
I might need some guide to port chibiOS to STM32373C-eval board
I followed
http://www.chibios.org/dokuwiki/doku.ph ... _rt_how-to
but it is for STM32F4xx)
However, at the compile stage. It gives compilation error says:
.\os\hal\platforms\STM32\GPIOv2\pal_lld.h(158): error: #256: invalid redeclaration of type name "GPIO_TypeDef" (declared at line 573 of "C:\Keil\ARM\PACK\Keil\STM32F3xx_DFP\1.0.0\Device\Include\stm32f30x.h")
.\os\hal\include\serial.h(111): error: #5: cannot open source input file "serial_lld.h": No such file or directory
Please give some hints
Thank you in advance
Re: porting ChibiOS to STM32373C-EVAL
You don't need to port anything, a demo for that board is already included in ChibiOS: ARMCM4-STM32F373-STM32373C_EVAL.
madokapeng
Giovanni wrote:Hi,
I want to develop it in KEIL IDE. I do not see any demo using KEIL
Please guide me
Thank ou
madokapeng
Please how to porting chibiOS under KEIL IDE
Thanks in advance
Some of the demos have Keip project files, you can use those as examples.
madokapeng
Giovanni wrote:Some of the demos have Keip project files, you can use those as examples.
is that for stm32373C-EVAL project?
I could not find any
madokapeng
Giovanni,
Thank you for your quick response. However, I am quite new to chibiOS. I need some information more details.
Please someone can give me a guide.
what documents I should look at?
I found most of demo project is not keil. there is only a few has keil project.
there is a folder under os/port/, called RVCT. what is RVCT? Is this used for keil?
Thanks in advance
Yes, RVCT is Keil.
The available documentation is on the web site here: http://www.chibios.org/dokuwiki/doku.ph ... :documents
The main document is the general documentation here: http://chibios.sourceforge.net/html/index.html
madokapeng
Giovanni wrote:Hi,
Yes, RVCT is Keil.
Then, the problem is under os\ports\RVCT\ARMCMx, it has STM32F1xx, STM32F4xx, STM32L1xx. There is no STM32F3xx.
what files should I import under port folder for STM32373C-EVAL?
Look at the Makefiles of the F3 demos and find the "include" (there are several of them), those .mk files contain all paths you have to use in your project.
