Page 2 of 2
Re: Compile-time Linker Error
Posted: Sat Nov 19, 2011 11:50 am
by darrowj08
I see. I have had success with eclipse in the past, with my forays into Java.
Perhaps I will follow your example. I did see a guide for using eclipse on the primary site.
Anyway, thanks for your support.
Technical update- my Linux based stlink utility seems to not want to flash or to correctively update ram to run a program.
It also said something to the effect of, Note- this board does not support Swim protocol.
So..: I'm guessing thats what swm in uVision is short for. Is that also what SWD means? Cause there appears to be a jumper available for that.
Posted: Sat Nov 19, 2011 4:01 pm
by DrunkenDonkey
After using a bit keil and iar a bit I can confirm iar is the better of them, but miles behind in terms of easy to use, modern development environment, and not mentioning the price tag at all. Granted, eclipse have its drawbacks too, trying to be too universal, also setting it up for embedded development can be challenging at the start and lose you several hours, but at the end it is every bit worth it, and besides, it is one time operation, copy-paste the next :D
Posted: Sat Nov 19, 2011 4:44 pm
That guide about Eclipse is a bit old, I will update it tomorrow adding notes about the use with Discovery kits.
Posted: Sun Nov 20, 2011 10:56 am
I just updated all the Eclipse-related guides and added a new guide about using ST-Link under Eclipse, please let me know if you find any error.
