Compile-time Linker Error
darrowj08
Post by darrowj08 »
So, To explain, I am a computer science student, I have had very little actual experience with uC programming and etc.
But here's the situation I am in.
IDE: Keil uVision
ChibiOS version 2.2.7
Target: STM32 Value Line: Discovery
Using ST-Link and SWD
Problem: On build, I get this output
 compiling etc etc
compiling main.c...
linking...
.\obj\ch.axf: Error: L6218E: Undefined symbol Image$$RW_IRAM2$$Base (referred from chmemcore.o).
Target not created
On attempted flash download (I cleared the flash memory first) I got an error about ch.axf not found.
And... I have no idea what to do.
I would really appreciate your help!
Thank you.
John Darrow
Re: Compile-time Linker Error
Hi John,
That error is related to a missing symbol, that symbol should be defined in the project options, there are several possible causes:
1) You are using an older uVision version (what version are you using ?).
2) Somehow you modified the project options and some settings changed (try to restore the demo from the distribution zip).
3) The project contains an error in 2.2.7 (I will verify this in the evening), you may try to confirm this by compiling some other Keil project in the meanwhile.
It worked here, please verify the above points.
darrowj08
Post by darrowj08 »
If it matters, I"m doing all this on a machine running Windows 7 Ult.
I have access to a mac running 10.6 as well as a second image on my pc with ubuntu on it.
IDE-Version:
µVision V4.22.22.0
Copyright (C) 2011 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers:
Toolchain: MDK-Lite Version: 4.22a
Toolchain Path: BIN40\
C Compiler: Armcc.Exe V4.1.0.791 [Evaluation]
Assembler: Armasm.Exe V4.1.0.791 [Evaluation]
Linker/Locator: ArmLink.Exe V4.1.0.791 [Evaluation]
Librarian: ArmAr.Exe V4.1.0.791 [Evaluation]
Hex Converter: FromElf.Exe V4.1.0.791 [Evaluation]
CPU DLL: SARMCM3.DLL V4.22a
Dialog DLL: DCM.DLL V1.3.0.0
Target DLL: STLink\ST-LINKIII-KEIL.dll V1.5.8
Dialog DLL: TCM.DLL V1.03
Above is the information from the About uVision... button
Also, this loaded as Preprocessor symbols>Define
__heap_base__=Image$$RW_IRAM1$$ZI$$Limit __heap_end__=Image$$RW_IRAM2$$Base
As far as 2:
I set the Debug program to use the ST-link debugger, and the subsequent setting to SWD
I redownloaded, and here's what happened when I tried to build.
compiling testthd.c...
compiling main.c...
linking...
Target not created
Again...
So, unless I'm missing something major here, it's not working.
Also, if it's relevant, when I just click Download, it tells me that ch.axf is not found.
Now I'm going to try compiling some random other thing with Keil to see if it works.
But please let me know if anything comes up based on the info I have above.
Thank you, by the way, for your quick response.
darrowj08
Post by darrowj08 »
I followed this set of instructions and I got a similar .axf undefined symbol error. I suspect there is either something wrong with my keil, or this sort of thing just doesn't work with the free version of Keil IDE.
I also noticed that my Dialog DLL was different from the one used in the tutorial I linked.
My Dialog DLL is TCM.DLL if that means anything.The Driver DLL is SARMCM3.DLL.
Please let me know if this provides any hints as to what I must do to make things work.
I use the free uVision 4.22.22, it should be your same version. That symbol is defined by defining a RAM area into the project options here:
Do you see the circled options?
darrowj08
Post by darrowj08 »
Okay, so, that appears to have worked, but... Well... I don't really know what to do next.
Keil when I click download says "Load (path)/ch.axf"
And it doesn't seem like it's programming the uC.
Or something like that. And... I have no idea what to do.
So basically, can you point me in the right direction?
You have to configure the debug settings to use ST-Link as probe. Go in the options->debug then select ST-Link and click on "Settings", then select SWD.
Now it should upload the code on the board.
darrowj08
Post by darrowj08 »
Sooo... I had already been doing that. And I discovered today that it would seem that my System viewer path or whatever it is would seem to be different from the one you seem to have running in your depicted example.
Also, I'm sorry to be so much trouble.
I also noticed that my copy of Keil uVision does not seem to have terribly persistent preferences. Hmmm.
So I'm doing two things. I'm going to reinstall the Keil Arm IDE, and I'm going to install the ST-Toolset from STM. Because, well, either I'm not understanding some miniscule distinction, or something is very wrong with the way uVision is managing it's memory, and probably won't work unless it's fixed.
If you have any hints or magical advice that I can use, I am all ears.
I am not so much dependent on using Keil's IDE. What I am dependent on is getting to where I can program a rudimentary algorithm set into this darn microcontroller.
I don't like uVision much, IAR is a bit easier to use, Anyway I prefer my custom Eclipse environment (harder to do but I love freedom).
