Stack size and overflows
kulve
Re: Stack size and overflows
Post by kulve »
I downloaded it but it seems to be Windows only :/
kulve
Post by kulve »
After clicking around a bit (thanks for the Eclipse setup docs) I got the stack dump with the ChibiOS plugin.
I attached it as a screenshot as I don't know how to get it out as text:
Stack dump
Stack dump
Anyway, to me it looks like there's plenty of free stack available for threads still..? (EDIT: well, I'm not sure how to read those..)
StkUnused is the available stack size in the moment you refreshed the view, apparently there is enough stack size. Note that the stack overflow check is done during context switching only so there could be instances of stack overflows not caught by the OS, for example calling a library function the does not perform any context switching inside.
Just a question, do you have the state checker enabled? Analyzing the trace buffer could also give an hint about the sequence of operations that brought to the overflow.
Without looking at the actual code and performing debug there is not much else I can do. BTW, is that a smart card related application?
kulve
Post by kulve »
I debugged this a bit further and started to write what actually happens when I realized that I'm calling chBSemWaitS(&sem) to lock a semaphore but I was calling chBSemSignal(&sem) to unlock it, instead of chBSemSignalI(&sem).
No "overflows" after fixing that.
Again just a stupid user error. But as always, thanks for your prompt replies.
mabl
Post by mabl »
But this would have been coughed by the state checker if you had enabled debugging, wouldn't it? :twisted:
kulve
Post by kulve »
At least I have this defined:
#define CH_DBG_ENABLE_STACK_CHECK       TRUE
I'm assuming that enables the state checker?
Nope, that is the stack check, it is CH_DBG_SYSTEM_STATE_CHECK. Regardless, during development all debug options should be enabled, the system is designed to catch a lot of errors if you allow it to do so.
kulve
Post by kulve »
Well, I must be blind. I did double check that I have all the defines set that are there in the debug wiki page. But I guess I can't distinguish stack from state :/
kulve
Post by kulve »
Thank you for the state checker. My locking stuff was a mess but now it's mostly fixed. Still something (hopefully small) remaining.
