I bumped into stack overflow in one of my threads. I increase the WORKING_AREA to 256 and it complained about another thread (I have two of them currently). I increased that one as well and now I get:
#0 port_halt () at ChibiOS/os/ports/GCC/ARMCMx/chcore.c:43 #1 0x08000742 in chDbgPanic (msg=0x8003c34 "stack overflow") at ChibiOS/os/kernel/src/chdebug.c:267 #2 0x08000bcc in chSchDoReschedule () at ChibiOS/os/kernel/src/chschd.c:302 #3 0x08000404 in _port_switch_from_isr () at ChibiOS/os/ports/GCC/ARMCMx/chcore_v7m.c:225 Backtrace stopped: frame did not save the PC (gdb)
I'm using f205 and -fno-omit-frame-pointer as I've understood -fomit-frame-pointer is bad on ARM for getting proper back traces.
So, what should I now increase? __main_stack_size__ and/or __process_stack_size__? If I touch those should I also change something else or is everything calculated accordingly automatically?
Are you compiling with -O0? if so try increasing PORT_INT_REQUIRED_STACK to 32 or 48. Compiling without optimizations makes the generated code use a lot more of space and it can make the idle thread overflow.
(you may override the default setting by adding it to chconf.h)
I'd like to change my project's stack configuration, but concerning the main stack und interrupt stack, I don't know how to do it. Is the main stack the region which is defined as stack area in the linker script, or are all stacks put into that area? The article about stack usage points to the ChibiOS port documentation, but I couldn't find it. I'm using STM32F4, and I even don't know if this thing has a dedicated interrupt stack. Giovanni, could you please post a link to the documentation of the port-dependent stack configuration?
The interrupts stack and C-runtime stack (main() function) are out of the OS control, those are handled by the startup files and configured in the .ld file:
__main_stack_size__ is the size of INTERRUPTS stack __process_stack_size__ is the stack of the C-runtime, in ChibiOS the "main" thread uses the C-runtime stack.
If you need to customize those values the best way is to copy the .ld file locally in your project, customize it and then make the Makefile point to the local copy.
(gdb) bt #0 port_halt () at ChibiOS/os/ports/GCC/ARMCMx/chcore.c:43 #1 0x08000962 in chDbgPanic (msg=0x8007f94 "stack overflow") at ChibiOS/os/kernel/src/chdebug.c:267 #2 0x08000ecc in chSchDoRescheduleAhead () at ChibiOS/os/kernel/src/chschd.c:340 #3 0x08000dd8 in chSchRescheduleS () at ChibiOS/os/kernel/src/chschd.c:251 #4 0x08007868 in sc_cmd_push_byte (byte=112 'p') at src/sc_cmd.c:101 #5 0x080074ec in rxchar (c=112) at src/sc_uart.c:420 #6 0x0800748a in rx1char_cb (uartp=0x2000193c, c=112) at src/sc_uart.c:379 #7 0x080065bc in uart_lld_serve_rx_end_irq (uartp=0x2000193c, flags=32) at ChibiOS/os/hal/platforms/STM32/USARTv1/uart_lld.c:229 #8 0x08003882 in Vector150 () at ChibiOS/os/hal/platforms/STM32F2xx/stm32_dma.c:374 #9 <signal handler called> #10 0x55555554 in ?? () #11 0x55555554 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) (gdb)
I do have quite an old version of ChibiOS currently but I doubt it's related to this problem.
I've tried to increase PORT_INT_REQUIRED_STACK to 128 and increasing __main_stack_size__ and __process_stack_size__ from 0x400 to 0x800 but I'm still getting the same panic. Any suggestions?
