ChibiOS OpenOCD support
mabl
Re: ChibiOS OpenOCD support
Post by mabl »
Thx, you are correct. :oops: That makes things easy.
mabl
Post by mabl »
Giovanni, I think the ch_root symbol is automatically removed by the GCC garbage collection.... :cry:
Mh, I have to reference it somewhere...
Could you add a "keep" to the linker script in the meanwhile? or just disable the GC in the Makefile.
mabl
Post by mabl »
i did so already. Disabling my GC will result in too big executable in my test program. I'm sure you'll find a nice place to reference it.
Best,
MaBl
dandys
Post by dandys »
Hi mabl,
maybe gcc __attribute__ ((used)) can also work for you to preserve structure. But don't know if any other commercial compilers has some similar option, so not sure about portability. Another solution would be put structure in dedicated section and use KEEP keyword for this input section in linker script.
noether
Post by noether »
mabl wrote:Giovanni, I think the ch_root symbol is automatically removed by the GCC garbage collection.... :cry:
From my ignorance in programming but, can not you just declare it as "volatile"? then the compiler will not remove it.
I never used "volatile" in that context but probably you are right, I will give it a try.
I missed this:
@dandys, I believe that __attribute__ is a GCC-specific extension.
dandys
Post by dandys »
Giovanni wrote:I missed this:
Agree. But there can be some similar extensions for other compilers too (as is for packed structures for example). In this case some macros like KEEP_SYMBOL_BEGIN and KEEP_SYMBOL_END can be defined in chtypes.h. Are some IAR or KEIL users arround? Anyway still not sure if this would be the best solution. Declaring as volatile won't work IMHO. At least I can't find it _must_ work in C89 spec.
Mhh, then I will just add a reference somewhere to the variable.
thanks,
