Page 17 of 18
Re: ChibiOS OpenOCD support
Posted: Fri Nov 09, 2012 2:30 pm
by Prof. Dr. YoMan
mabl wrote:I've deleted the link. Freddie could I ask you to create a new build from oocd master? I'm not expert in this windows stuff...
This would be nice! A "daily" build of openocd-dev. :)
Posted: Fri Nov 09, 2012 2:40 pm
by Freddie Chopin
OK, if you say that now it's stable enough I can do that.
I'll send info when it's done, but I don't know whether I'm going to make it today.
4\/3!!
Posted: Fri Nov 09, 2012 2:43 pm
by mabl
Yeah it's stable enough. I thanks Freddie, sorry for the mess.
Posted: Fri Nov 09, 2012 3:18 pm
by mabl
12:23:55 PM - mabl00: Guys, about the unfortunate troubles with the closed source ftdi drivers. I've never cared for it before, since I do not use Windows. How serious is this taken if i distribute a oocd which is linked to those drivers?
12:24:26 PM - mabl00: Or is there a simple replacement which also works for crosscompiling from linux?
02:06:23 PM - ntfreak: mabl00: I personally have no issue with it, others however do.
02:06:23 PM - ntfreak: If possible i would suggest you use the new ftdi driver, the issue is that you will need to swap drivers in windoze.
02:09:16 PM - ntfreak: If they want to keep the original ftdi drivers then as far as i know you have two choices
02:09:16 PM - ntfreak: 1. build with ftd2xx
02:09:16 PM - ntfreak: 2. build with libusb-win32 and use the filter driver
02:09:16 PM - ntfreak: there may ne others that i am not aware off.
Posted: Sat Nov 10, 2012 12:15 pm
by mabl
The endiness fixes introduced an unfortunate copy and paste error: http://openocd.zylin.com/#/c/974/
Posted: Mon Nov 12, 2012 10:48 am
by mabl
mabl wrote:The endiness fixes introduced an unfortunate copy and paste error: http://openocd.zylin.com/#/c/974/
Fix just got committed in master - which is now expected to work "flawless" :ugeek:
Posted: Mon Nov 12, 2012 1:23 pm
by Freddie Chopin
I've noticed, so I'll proceed with this compilation for you (;
4\/3!!
Posted: Mon Nov 12, 2012 5:44 pm
by Freddie Chopin
The binary is available for download from my website.
4\/3!!
Posted: Tue Nov 13, 2012 10:17 am
by mabl
Thx Freddie! Let's see if I can get feedback from the Windows guys :D
Posted: Tue Nov 13, 2012 3:52 pm
by Prof. Dr. YoMan
Will this be backported to 2.4.3 (which is due to release?)?
Since I am at the starting point to develop for a product I would not wan't to use 2.5.x, but it would be great to see this in 2.4.x because it significantly helps debugging.
And what about M4-F enabled? Where is the problem with the FPU?
