C++ and STM32
Re: C++ and STM32
Thanks for that pointer Giovanni, increasing the main and process stack sizes has fixed it
Re: C++ and STM32
Heh, careful, the main() function stack is the "process stack", the "main stack" is the stack for interrupts. It is a bit of a mess but those are the names ARM gave them.
Re: C++ and STM32
Giovanni wrote:Heh, careful, the main() function stack is the "process stack", the "main stack" is the stack for interrupts. It is a bit of a mess but those are the names ARM gave them.
Thanks, that makes sense, I have returned __main_stack_size__ to it's original value!
Re: C++ and STM32
Just a heads up,
It works fine on the STM32F4DISCOVERY with some minor changes of course.
I had to increase the stack size as well. Else I cannot create more than 3x128 bytes threads.
Is this the "normal" way of fixing the issue or just a temporary workaround?
Re: C++ and STM32
I, for one, use the C API in my C++ projects. It's just too troublesome to access some functions in the correct scopes. For example, imagine that I create some hardware abstraction class and this class needs the delay functions. From where should I call it? Must I have a pointer to the caller thread object just so I can call the delay function? Should the delay function be a static member? If it is static, why not just call the C API?
Re: C++ and STM32
Xamusk wrote:I, for one, use the C API in my C++ projects. It's just too troublesome to access some functions in the correct scopes. For example, imagine that I create some hardware abstraction class and this class needs the delay functions. From where should I call it? Must I have a pointer to the caller thread object just so I can call the delay function? Should the delay function be a static member? If it is static, why not just call the C API?
Hello Xamusk, I faced the same problems in the past mixing C (RTOS) and C++ (my stuff) in microcontrollers. This FAQ solved to me many of these problems,
http://www.parashift.com/c++-faq-lite/m ... d-cpp.html . I hope this could be useful for you.
Cheers.
Re: C++ and STM32
I would like to continue this discussion with some issues that I am facing.
I am including Eigen library (http://eigen.tuxfamily.org/index.php?title=Main_Page) just modifying the demo project.
During the compilation, I do not have any problems if I set the flags to -O2 -DNDEBUG . But once I do not want any optimization for an easy gdb debugging, putting -O0 the linker complains as follows:
Do you know if I can solve this issue with any flag, or adding another external source like syscalls.c?
If I remove the Matrix operations lines, the code compiles without any problems.
Cheers
#include "ch.h"
#include "Eigen/Dense"
using namespace Eigen;
static WORKING_AREA(waThread1, 128);
(void)arg;
int i = 1;
float valor[2];
Matrix<float, 3, 3> A, L;
A = Matrix<float, 3, 3>::Identity(3, 3) +
Matrix<float, 3, 3>::Constant(1);
while (TRUE)
i++;
L = A.llt().matrixL();
A(0, 0) += i;
valor[0] = L(0, 0);
valor[1] = L(1, 1);
palSetPad(GPIOD, GPIOD_LED3); /* Orange. */
chThdSleepMilliseconds(500);
palClearPad(GPIOD, GPIOD_LED3); /* Orange. */
int main(void) {
while (TRUE) {
Linking build/ch.elf
/home/noether/workspace/tool-chains/arm-none-eabi-4.6.2/lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/cortex-m4/libc.a(lib_a-abort.o): In function `abort':
/home/noether/workspace/tool-chains/summon-arm-toolchain/build/arm-none-eabi/thumb/cortex-m4/newlib/libc/stdlib/../../../../../../../gcc-4.6.2/newlib/libc/stdlib/abort.c:63: undefined reference to `_exit'
/home/noether/workspace/tool-chains/arm-none-eabi-4.6.2/lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/cortex-m4/libc.a(lib_a-signalr.o): In function `_kill_r':
/home/noether/workspace/tool-chains/summon-arm-toolchain/build/arm-none-eabi/thumb/cortex-m4/newlib/libc/reent/../../../../../../../gcc-4.6.2/newlib/libc/reent/signalr.c:61: undefined reference to `_kill'
/home/noether/workspace/tool-chains/arm-none-eabi-4.6.2/lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/cortex-m4/libc.a(lib_a-signalr.o): In function `_getpid_r':
/home/noether/workspace/tool-chains/summon-arm-toolchain/build/arm-none-eabi/thumb/cortex-m4/newlib/libc/reent/../../../../../../../gcc-4.6.2/newlib/libc/reent/signalr.c:96: undefined reference to `_getpid'
collect2: ld returned 1 exit status
make: *** [build/ch.elf] Error 1
Cheers
Re: C++ and STM32
Probably without optimizations unused code is not removed, you have to provide stub implementations of those calls in syscall.c (I would put just a chSysHalt() inside for debug).
Re: C++ and STM32
Many thanks, it could compiled it. Now let see if the program runs correctly
Well, it doesn't xD.
The binary file is close to 130KB (it is 13KB with -O2 -DNDEBUG), and it crashes at the end of vectors.c .
Edit
Already I can get around the problem just with adding some "volatile" for avoiding the optimizations. If you are interested, I can dedicate more time to know what is happening, but I do not know where I have to start.
Edit
