New from ST: "Nucleo" boards
Re: New from ST: "Nucleo" boards
"break" makes the main() return and go boom.
Oh, I didn't even see those...
@Giovanni: But is it correct that one has to manually change the PLL values when changing from HSE to HSI or am I giving wrong advice here?
jcw
Post by jcw »
Ah, thanks - this is what I have now, I'll investigate!
#define STM32_PLLSRC                        STM32_PLLSRC_HSI
#define STM32_PLLXTPRE                      STM32_PLLXTPRE_DIV1
#define STM32_PLLMUL_VALUE                  9
Above example simplified, as per your suggestion. I also removed the "break" commands, leftover from an old edit.
jcw
Post by jcw »
Definitely a clock issue, this one blinks just fine:
  while (true) {
    palTogglePad(GPIOA, GPIOA_LED_GREEN);
    for (volatile int i = 0; i < 1000000; ++i)
    // chThdSleepMilliseconds(1);
Ok, that narrows it down considerably.
-jcw
PS. You guys are amazing, helping out within minutes!
jcw
Post by jcw »
Problem solved - I had turned off the idle thread, now restored to:
#define CH_CFG_NO_IDLE_THREAD               FALSE
Can't do a chThdSleepMilliseconds() in main() when there's no idle thread to switch to - doh!
Final test code, for reference:
#include "ch.h"
int main () {
  while (true) {
    chThdSleepMilliseconds(500);
  return 0;
All is well now, both tick-less and with periodic ticks. Onwards!
-jcw
