New from ST: "Nucleo" boards
New generation boards: http://www.st.com/stonline/stappl/produ ... rcetype=HW
Apparently the new boards have a new ST-Link, Arduino-like connectors and new ST "standard" connectors. This means that it should be possible to make shields or motherboards usable with any Nucleo module.
Those boards are more naked than Discovery kits, no mems or other peripherals, discovery kits apparently are now positioned differently.
Re: New from ST: "Nucleo" boards
This looks quite interesting! Thanks for the news.
Price is VERY interesting too :)
See Farnell for example.
colin
Post by colin »
Very nice! This really seems to compete directly with the Freescale Kinetis "Freedom" boards like the popularFRDM-KL25Z. They can be had for about 13.00 USD (Digi-Key) and have on-board "OpenSDA" debugger and USB-serial converter (however these are IMO poorly implemented) and have a Arduino compatible headers. However, the Arduino headers are not provided with the board, so you have to purchase and solder them yourself which adds to the cost/effort to get up and running.
russian
Has thanked: 16 times
Been thanked: 14 times
Post by russian »
I wonder if these new boards are covered by the same evaluation license as discovery?
I just do not see the 'Legal' section on the http://www.st.com/web/catalog/tools/FM1 ... 7/PF260000 page the way is is present at http://www.st.com/web/catalog/tools/FM1 ... 2/PF252419
Maybe they have forgotten to place it there :)
tronicgr
Post by tronicgr »
I just got in my hands the Nucleo-F401RE.
I was confused on how you load the code with mbed... until I read that you just drag drop the ".bin" file to the drive that is created upon you connect the board... Cool!
I suppose you could use another compiler and drag and drop the bin file the same way! :)
Any plans for porting to Chibios?
Thanos
Of course, I am waiting a new release of OpenOCD because the new STLink is not compatible with the current one.
Tommino
Post by Tommino »
ST-Link from http://www.st.com/web/en/catalog/tools/PF258168# is working from the command line:
c:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility>ST-LINK_CLI.exe -ME
STM32 ST-LINK CLI v1.9.0
STM32 ST-LINK Command Line Interface
Connected via SWD.
Connetion mode : Normal.
ST-LINK Firmware version : V2J19S3
Device ID:0x433
Device flash Size : 512 Kbytes
Device family :STM32F401xE
Full chip erase...
Flash memory erased.
c:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility>ST-LINK_CLI.exe -P c:\xxx\yyy.bin 0x08000000 -V -Rst
Connected via SWD.
Device ID:0x433
Loading file...
Flash Programming:
File : c:\xxx\yyy.bin
Address : 0x08000000
Flash memory programming and verification...
¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦¦ 100%
The file is downloaded successfully.
Verification...OK
Programming Complete.
MCU Reset.
My experience with ST-Link is better because in case of "drag&drop" flashing, VCP will not work after and it's necessary to restart the board completely.
Ciao,
Tommino
Djuro
Post by Djuro »
https://github.com/texane/stlink - is Nucleo ready too.......
Djuro
jcw
Post by jcw »
One difference seems to be that the boards come without a crystal for the main clock.
-jcw
