Page 4 of 6
Re: STM32f103VET6 Bootloader jump problem.
Posted: Wed Jun 10, 2015 10:10 am
I cannot give advice about this, you have to discover where it goes in exception.
Posted: Wed Jun 10, 2015 10:16 am
by franek.bmw
It goes to exception at the and of this function, in Jump_To_Application();
void jumpToUser(uint32_t address) {
   typedef void (*pFunction)(void);
   pFunction Jump_To_Application;
   /* variable that will be loaded with the start address of the application */
   vu32* JumpAddress;
   const vu32* ApplicationAddress = (vu32*) address;
   if (((*(unsigned long*)address) & 0x2FFE0000 ) == 0x20000000)
      /* get jump address from application vector table */
      JumpAddress = (vu32*) ApplicationAddress[1];
      /* load this address into function pointer */
      Jump_To_Application = (pFunction) JumpAddress;
      /* Clear pending interrupts just to be on the safe side*/
      SCB_ICSR = ICSR_PENDSVCLR;
      /* Disable all interrupts */
      uint8_t i;
      for(i=0; i<8; i++)
         NVIC->ICER[i] = NVIC->IABR[i];
      /* set stack pointer as in application's vector table */
      __set_MSP((u32) (ApplicationAddress[0]));
Posted: Wed Jun 10, 2015 11:09 am
Try to single step instruction by instruction. There must be one that causes the crash.
Posted: Thu Jun 11, 2015 7:40 am
by franek.bmw
I found bug! :-) In my app I make in RAM fifo which overflow memory. When I reduce size of fifo all is good.
So I have a question. Probably when processor jump from bootloader to app in RAM remain some unnecessarily variables. It is possible to release this area of RAM?
BTW: If my application was written in CHIBIOS, I would have found this problem much earlier. But when I wrote it, I did not know yet CHIBIOS ;-)
Posted: Thu Jun 11, 2015 8:05 am
When you jump to the application the bootloader is no more active (I assume), you can use all the RAM.
Posted: Thu Jun 11, 2015 8:09 am
by franek.bmw
So what can caused this lack of memory?
Franek
Posted: Thu Jun 11, 2015 8:39 am
Sorry, I don't understand...
Posted: Thu Jun 11, 2015 9:04 am
by franek.bmw
When I have only app, my fifo size could be 500B, when I have bootloader too, my fifo in app could be only 120B. Why?
Posted: Thu Jun 11, 2015 9:23 am
You are asking me things specific to your setup, how I am supposed to answer?
I can only recommend to study the map files in order to understand the memory organization of your application, then eventually evaluate changes to the .ld scripts.
Posted: Mon Jun 15, 2015 12:05 pm
by franek.bmw
Could you give me some clue, if I send to you my linker script or map files?
