STM32f103VET6 Bootloader jump problem.
franek.bmw
Post by franek.bmw »
I am just writing my own bootloader for stm32f103vet6. I wanted to test jump to address of application. I have not yet written my app so I am testing that bootloader jump to its beginning (something like soft reset). I stop the OS like is described in http://www.chibios.org/dokuwiki/doku.ph ... os:stop_os , then I make a jump. Then bootloader start working from the beginning but after a while the stack overflow occurs. Chibiplugin indicates that the stack of main thread is overflow and the size of main stack is 0x000000. What is wrong in my code, that such an error occurs?
Below is a piece of code where I turn off the system and jumps.
Can somebody help me? Thank you very much in advance.
void jump_to_app(void)
chThdTerminate(tp_error_handler);              /* Requesting termination.                  */
         chThdWait(tp_error_handler);                  /* Waiting for the actual termination.      */
         chThdTerminate(tp_led_display);              /* Requesting termination.                  */
         chThdWait(tp_led_display);          /* Waiting for the actual termination.      */
         chThdTerminate(tp_can_parser);     /* Requesting termination.                  */
         chThdWait(tp_can_parser);          /* Waiting for the actual termination.      */
         chThdTerminate(tp_can_tx);     /* Requesting termination.                  */
         chThdWait(tp_can_tx);          /* Waiting for the actual termination.      */
         chThdTerminate(tp_load_bargraph);     /* Requesting termination.                  */
         chThdWait(tp_load_bargraph);          /* Waiting for the actual termination.      */
         chThdTerminate(tp_leds_handler);     /* Requesting termination.                  */
         chThdWait(tp_leds_handler);
         canStop(&CAND1);
         if(!((GPTD2.state == GPT_STOP) || (GPTD2.state = GPT_READY)))
            gptStop(&GPTD2);
         sdStop(&SD1);
         chSysDisable();
         SysTick->CTRL = 0; //disable SysTick
         chSysEnable();
         jumpToUser(0x08000000);
jumpToUser function code:
void jumpToUser(uint32_t address) {
  typedef void (*pFunction)(void);
  pFunction Jump_To_Application;
  /* variable that will be loaded with the start address of the application */
  vu32* JumpAddress;
  const vu32* ApplicationAddress = (vu32*) address;
  /* get jump address from application vector table */
  JumpAddress = (vu32*) ApplicationAddress[1];
  /* load this address into function pointer */
  Jump_To_Application = (pFunction) JumpAddress;
  /* Clear pending interrupts just to be on the safe side*/
  SCB_ICSR = ICSR_PENDSVCLR;
  /* Disable all interrupts */
  uint8_t i;
  for(i=0; i<8; i++)
    NVIC->ICER[i] = NVIC->IABR[i];
  /* set stack pointer as in application's vector table */
  __set_MSP((u32) (ApplicationAddress[0]));
  Jump_To_Application();
Re: STM32f103VET6 Bootloader jump problem.
Have you relocated the vectors table in the loaded application? You can redefine CORTEX_VTOR_INIT in chconf.h.
franek.bmw
I have to do this even I jump from bootloadet to bootloader?
You have to do this if your vectors table does not start from address zero.
franek.bmw
I make this definition in chconf.h
#define CORTEX_VTOR_INIT 0x08000000
0x08000000 is also my app address where I want to jump.
Stack overflows still occure :(
Franek
I have no elements to help.
You posted some code but the problem likely is in the memory organization and C runtime initialization.
franek.bmw
Which file I should posted?
I am using demo project from ChibiOS_2.6.7/demos/ARMCM3-STM32F103 where I change in makefile only linker script from STM32F103xB.ld to STM32F103xE.ld.
franek.bmw wrote:Which file I should posted?
I could answer this if I knew where the problem is...
If you jump to the reset address and then it fails then there must be something you did not de-initialize. Are stacks re-initialized correctly?
franek.bmw
How to check it?
I modeled on that project as well https://github.com/fpoussin/ChibiOS-Boo ... loader_app . The difference is that I do not jump to the beginning of the application but to the beggining of the bootloader.
Franek
Placing breakpoints into the startup file and verifying that everything is as expected.
Inspecting stack after the crash could also give hints.
