Can you submit a patch? or just post on the forum the modified code. I need to modify the test application to trigger the problem also.
ctxp corrupted in _port_irq_epilogue
jbrandmeyer_bwp
Re: ctxp corrupted in _port_irq_epilogue
Change to the context switching code:
A snippet that enables FPU faults:
Index: chcore_v7m.c
--- chcore_v7m.c (revision 670)
+++ chcore_v7m.c (working copy)
@@ -166,6 +166,7 @@
populate it fully.*/
ctxp--;
ctxp->xpsr = (regarm_t)0x01000000;
+ ctxp->fpscr = (regarm_t)SCB_FPDSCR;
asm volatile ("msr PSP, %0" : : "r" (ctxp) : "memory");
/* The exit sequence is different depending on if a preemption is
@@ -249,6 +250,8 @@
void _port_thread_start(void) {
chSysUnlock();
+ // TODO: LTO doesn't understand that this code invokes chThdExit().
+ // chThdExit() needs to be marked "used"
asm volatile ("mov r0, r5 \n\t"
"blx r4 \n\t"
"bl chThdExit");
#include <ch.h>
#include <hal.h>
#include <stm32f4xx.h>
static void __attribute__((constructor))
configure_fpu_exceptions(void)
// Enable the FPU_IRQHandler
nvicEnableVector(FPU_IRQn, 1);
CH_IRQ_HANDLER(FPU_IRQHandler)
// Force a hard reset on FPU exceptions
NVIC_SystemReset();
Thanks for the patch, the LTO issue has been addressed in 3.0, the whole thing has been moved in a plain assembler module.
I committed the changes in both 2.6.x and 3.0.0, the test application has been updated as well and is able to detect the problem. 2.6.6 will probably be released next week.
Marked as bug #533.
Thank you for the patch and analysis of the problem.
Marked as bug #533.
