Re: STM32f103VET6 Bootloader jump problem.
Posted: Mon Jun 15, 2015 12:30 pm
Post what you think could help on the forum, no guarantee, it is very out of scope of ChibiOS support.
ChibiOS Web Boards
https://forum.chibios.org/
Default linker script for STM32F10x
Martin Thomas, 9/2009
A heavily modified "Default linker script for STM32F10x_512K_64K"
Copyright RAISONANCE S.A.S. 2008 found in the STM fw-library.
/* Program Entry, set to mark it as "used" and avoid gc */
ENTRY(Reset_Handler)
/* Memory Spaces Definitions */
MEMORY
RAM (RWX) : ORIGIN = 0x20000000, LENGTH = 64K
EXTSRAM (RWX) : ORIGIN = 0x68000000, LENGTH = 0
FLASH (RX) : ORIGIN = 0x08020000, LENGTH = 512K - 128K -2K
EEMUL (RWX) : ORIGIN = 0x08020000+512k-128K - 2K, LENGTH = 2k
FLASHB1 (RX) : ORIGIN = 0x00000000, LENGTH = 0
EXTMEMB0 (RX) : ORIGIN = 0x00000000, LENGTH = 0
EXTMEMB1 (RX) : ORIGIN = 0x00000000, LENGTH = 0
EXTMEMB2 (RX) : ORIGIN = 0x00000000, LENGTH = 0
EXTMEMB3 (RX) : ORIGIN = 0x00000000, LENGTH = 0
/* higher address of the user mode stack */
_estack = ORIGIN(RAM)+LENGTH(RAM);
/* start of the two 1kByte pages used by EEprom emulation at end of flash */
_seemul = ORIGIN(EEMUL);
/* There will be a link error if there is not this amount of RAM free at the end. */
_Minimum_Stack_Size = 0x100 ;
/* Check valid alignment for VTOR */
ASSERT(ORIGIN(FLASH) == ALIGN(ORIGIN(FLASH), 0x80), "Start of memory region flash not aligned for startup vector table");
/* Sections Definitions */
SECTIONS
/* the program code is stored in the .text section, which goes to Flash */
.text :
. = ALIGN(0x80); /* PM0056, Rev.1 (4/2009), 4.3.3 */
_isr_vectorsflash_offs = . - 0x08000000;
KEEP(*(.isr_vectorsflash))
. = ALIGN(4);
*(.text) /* code */
*(.text.*) /* remaining code (-ffunction-sections)*/
*(.stub .gnu.linkonce.t.*)
*(.rodata .rodata.* .gnu.linkonce.r.*) /* read-only data (constants) */
*(.glue_7 .glue_7t) /* redundant for thumb2 ?! */
_etext = .;
_sidata = _etext;
. = ALIGN(4);
} >FLASH
/* This is the initialized data section
The program executes knowing that the data is in the RAM
but the loader puts the initial values in the FLASH (inidata).
It is one task of the startup to copy the initial values from FLASH to RAM. */
.data : AT ( _sidata )
. = ALIGN(4);
/* This is used by the startup in order to initialize the .data section */
_sdata = . ;
. = ALIGN(4);
_adresZaWektoremPrzerwan = .;
KEEP(*(.pFuncArr)) /* functions pointers array */
. = ALIGN(0x80);
_isr_vectorsram_offs = . - 0x20000000;
KEEP(*(.isr_vectorsram))
. = ALIGN(4);
*(.ramfunc*)
. = ALIGN(4);
*(.data .data.* .gnu.linkonce.d.*)
. = ALIGN(4);
_edata = . ;
} >RAM
/* This is the uninitialized data section */
.bss (NOLOAD):
. = ALIGN(4);
/* This is used by the startup in order to initialize the .bss section */
_sbss = .;
*(.bss .bss.*)
*(COMMON)
. = ALIGN(4);
_ebss = . ;
} >RAM
PROVIDE ( end = _ebss );
PROVIDE ( _end = _ebss );
/* This is the user stack section
This is just to check that there is enough RAM left for the User mode stack
It should generate an error if it's full.
._usrstack (NOLOAD):
. = ALIGN(4);
_susrstack = . ;
. = . + _Minimum_Stack_Size ;
. = ALIGN(4);
_eusrstack = . ;
} >RAM
/* this is the FLASH Bank1 */
/* the C or assembly source must explicitly place the code or data there
using the "section" attribute */
.b1text :
*(.b1text) /* remaining code */
*(.b1rodata) /* read-only data (constants) */
*(.b1rodata*)
} >FLASHB1
/* this is the EXTMEM */
/* EXTMEM Bank0 */
.eb0text :
*(.eb0text) /* remaining code */
*(.eb0rodata) /* read-only data (constants) */
*(.eb0rodata*)
} >EXTMEMB0
/* EXTMEM Bank1 */
.eb1text :
*(.eb1text) /* remaining code */
*(.eb1rodata) /* read-only data (constants) */
*(.eb1rodata*)
} >EXTMEMB1
/* EXTMEM Bank2 */
.eb2text :
*(.eb2text) /* remaining code */
*(.eb2rodata) /* read-only data (constants) */
*(.eb2rodata*)
} >EXTMEMB2
/* EXTMEM Bank0 */
.eb3text :
*(.eb3text) /* remaining code */
*(.eb3rodata) /* read-only data (constants) */
*(.eb3rodata*)
} >EXTMEMB3
/* after that it's only debugging information. */
/* remove the debugging information from the standard libraries */
/* DISCARD :
libc.a ( * )
libm.a ( * )
libgcc.a ( * )
/* Stabs debugging sections. */
.stab 0 : { *(.stab) }
.stabstr 0 : { *(.stabstr) }
.stab.excl 0 : { *(.stab.excl) }
.stab.exclstr 0 : { *(.stab.exclstr) }
.stab.index 0 : { *(.stab.index) }
.stab.indexstr 0 : { *(.stab.indexstr) }
.comment 0 : { *(.comment) }
/* DWARF debug sections.
Symbols in the DWARF debugging sections are relative to the beginning
of the section so we begin them at 0. */
/* DWARF 1 */
.debug 0 : { *(.debug) }
.line 0 : { *(.line) }
/* GNU DWARF 1 extensions */
.debug_srcinfo 0 : { *(.debug_srcinfo) }
.debug_sfnames 0 : { *(.debug_sfnames) }
/* DWARF 1.1 and DWARF 2 */
.debug_aranges 0 : { *(.debug_aranges) }
.debug_pubnames 0 : { *(.debug_pubnames) }
/* DWARF 2 */
.debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
.debug_macinfo 0 : { *(.debug_macinfo) }
/* SGI/MIPS DWARF 2 extensions */
.debug_weaknames 0 : { *(.debug_weaknames) }
.debug_funcnames 0 : { *(.debug_funcnames) }
.debug_typenames 0 : { *(.debug_typenames) }
.debug_varnames 0 : { *(.debug_varnames) }
/* DWARF 3 */
.debug_pubtypes 0 : { *(.debug_pubtypes) }
.debug_ranges 0 : { *(.debug_ranges) }
.ARM.attributes 0 : { KEEP (*(.ARM.attributes)) KEEP (*(.gnu.attributes)) }
.note.gnu.arm.ident 0 : { KEEP (*(.note.gnu.arm.ident)) }
/DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) }
/* default stack size(s). These are used by the startup in order to allocate stacks for
the different modes. */
__Stack_Size = 1024 ;
PROVIDE ( _Stack_Size = __Stack_Size ) ;
__Stack_Init = _estack - __Stack_Size ;
/*"PROVIDE" allows to easily override these values from an object file or the commmand line.*/
PROVIDE ( _Stack_Init = __Stack_Init ) ;
/* set stack pointer as in application's vector table */
__set_MSP((u32) (ApplicationAddress[0]));
Jump_To_Application();Code: Select all
uint32_t reg;
/* CPU mode initialization. (disable dual stack mode)*/
reg = 0;
asm volatile ("msr CONTROL, %0" : : "r" (reg));
asm volatile ("isb");
