[DONE] The New STM32F429/F439
ilovezeno
Re: [TODO] The New STM32F429/F439
Post by ilovezeno »
trepidacious wrote:I've just got hold of a Discovery 429, I was planning to try out ChibiOS on it, starting with modifying the mcuconf and board files from the discovery 407 versions.
Is there anything else to watch out for? Giovanni mentioned changes to the HAL, I guess there would be changes needed to support additional hardware like the extra SPI channels etc. Are the peripherals that the 429 shares with the 407 likely to work without modifications?
Ben.
Can you have a look on the chip version of STM32f429 on the kit? version A or Y?
Because there is a big bug for version A's sdram.....
ilovezeno
Post by ilovezeno »
Ps you can find the chip version "Y" or "A" near the ST marker on the chip surface.
ilovezeno wrote:Because there is a big bug for version A's sdram.....
Can you give some more information about that? (I didn't read any errata yet...)
ilovezeno
Post by ilovezeno »
Now there is errata online.
The bug is if the CPU is visiting sdram, and there is a interrupt coming, then it will be a fault. So you can't use sdram by CPU...
ilovezeno wrote:The bug is if the CPU is visiting sdram, and there is a interrupt coming, then it will be a fault. So you can't use sdram by CPU...
Oh dear... but that sounds quite terrible... What are the proper workaround?
ilovezeno
Post by ilovezeno »
Only use DMA to visit sdram or using the version Y chip.....
ilovezeno wrote:Only use DMA to visit sdram or using the version Y chip.....
Good that Giovanni always provides us with "DMA where possible"-HAL drivers anyway :P
It seems there is a workaround by enabling the burst mode: http://www.st.com/web/en/resource/techn ... 068628.pdf
Edit: no, there is no workaround except use DMA or disable interrupts...
tronicgr
Post by tronicgr »
I see 22 available today!!! http://www.digikey.com/product-search/en?vendor=0&keywords=497-13898-ND
Mine is shipped today! :D
Thanos
ilovezeno
Post by ilovezeno »
tronicgr wrote:I see 22 available today!!! http://www.digikey.com/product-search/en?vendor=0&keywords=497-13898-ND
Thanos
Please, check the chip version after you receive it! Thanks~ :D
