ChibiOS OpenOCD support
Re: ChibiOS OpenOCD support
I would go for chSysInit because it is the API that is necessarily invoked at least one time.
mabl
Post by mabl »
Ok, status report:
During my work on the oocd patches, a lot of bugs have been detected inside the rtos code itself. :? Those code parts have been replaced by new code now and this is already upstream.
The main ChibiOS patch is still under review though. There are automatic style checks which i failed disastrously at first. At least, the build bots don't complain anymore.
Best, MaBl
Interesting those automatic checks, we could adopt something similar, how is it done?
mabl
Post by mabl »
openocd uses the GIT Review system gerrit and the Build-Bot jenkins. The build bot will invoke the style check during build process.
The check itself is a perl skript: https://github.com/mabl/openocd_chibios ... ckpatch.pl
But I think there are lot's of style checkers on the market.
Generally, I'd very much like to see the repository improved. Especially regarding commit messages, automatic build/testsuit checks and Changelog :ugeek:
feanor
Post by feanor »
i was excited to explore this feature, but unfortunately I'm not able to set it up properly. I've made a git-clone of the mentioned OpenOCD-branch into a Ubuntu-VM, crosscompiled it via mingw32 for windows and copied the binary into the openocd-environment of version 0.6. After this i followed the instructions made in wiki. But there are still no threads in debug-view of eclipse. A verbose debugging shows following line:
&"warning: RMT ERROR : failed to get remote thread list.\n"
What information is needed to help me getting threaded debugging view ;)
Many thanks in advance.
mabl
Post by mabl »
Hi feanor,
looks like your openocd does not detect ChibiOS. Could you post the whole debug output off eclipse/gdb and oocd? When copying to the 0.6 environment, did you append -rtos auto like described in the guide?
feanor
Post by feanor »
Hi mabl,
the gdb-output looks like
776-gdb-set confirm off
776^done
(gdb)
777-gdb-set width 0
777^done
(gdb)
778-gdb-set height 0
778^done
(gdb)
779-interpreter-exec console echo
779^done
780-gdb-show prompt
(gdb)
780^done,value="(gdb) "
(gdb)
781-gdb-set new-console on
781^error,msg="No symbol table is loaded.  Use the \"file\" command."
(gdb)
782-target-select remote localhost:3333
=thread-group-started,id="i1",pid="42000"
=thread-created,id="1",group-id="i1"
*stopped,frame={addr="0x080120f2",func="??",args=[]},thread-id="1",stopped-threads="all"
782^connected
(gdb)
783 info proc
&"info proc\n"
&"Undefined info command: \"proc\".  Try \"help info\".\n"
783^error,msg="Undefined info command: \"proc\".  Try \"help info\"."
784 monitor flash probe 0
(gdb)
&"monitor flash probe 0\n"
@"stm32f4x errata detected - fixing incorrect MCU_IDCODE\n"
@"device id = 0x10006413\n"
@"flash size = 1024kbytes\n"
@"flash 'stm32f2x' found at 0x08000000\n"
784^done
(gdb)
785 monitor flash protect 0 0 127 off
&"monitor flash protect 0 0 127 off\n"
@"ERROR: last sector must be <= 11\n"
@"in procedure 'flash'\n"
785^done
(gdb)
786 info program
&"info program\n"
~"Debugging a target over a serial line.\n"
~"Program stopped at 0x80120f2.\n"
~"It stopped with signal SIGTRAP, Trace/breakpoint trap.\n"
~"Type \"info stack\" or \"info registers\" for more information.\n"
786^done
(gdb)
787 info threads
&"info threads\n"
~"* 1 Remote target  0x080120f2 in ?? ()\n"
787^done
788 monitor reset halt
(gdb)
&"monitor reset halt\n"
monitor reset halt
@"target state: halted\n"
@"target halted due to debug-request, current mode: Thread \n"
@"xPSR: 0x01000000 pc: 0x08002670 msp: 0x20000400\n"
788^done
(gdb)
789-stack-info-depth
789^done,depth="2"
(gdb)
790 monitor stm32f2x mass_erase 0
&"monitor stm32f2x mass_erase 0\n"
@"stm32x mass erase complete\n"
790^done
(gdb)
791-stack-list-frames 0 2
791^done,stack=[frame={level="0",addr="0x080120f2",func="??"},frame={level="1",addr="0x08002762",func="??"}]
(gdb)
792 monitor flash write_image ../stm32-mf-chibios/src/build/chibi-mf.elf
&"monitor flash write_image ../stm32-mf-chibios/src/build/chibi-mf.elf\n"
@"target halted due to breakpoint, current mode: Thread \n"
@"xPSR: 0x61000000 pc: 0x20000042 msp: 0x20000400\n"
@"wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 1.913086s (42.993 KiB/s)\n"
792^done
(gdb)
793-data-list-changed-registers
793^done,changed-registers=["0","1","2","3","4","5","6","7","8","9","10","11","12","13","14","15","16","17","18","19","20","21","22","23","24","25"]
(gdb)
794 monitor flash protect 0 0 127 on
&"monitor flash protect 0 0 127 on\n"
794^done
(gdb)
795 info sharedlibrary
&"info sharedlibrary\n"
~"No shared libraries loaded at this time.\n"
795^done
(gdb)
796 disconnect
&"disconnect\n"
disconnect
=thread-group-exited,id="i1"
796^done
797 target remote localhost:3333
(gdb)
&"target remote localhost:3333\n"
~"0x08002670 in ?? ()\n"
0x08002670 in ?? ()
*stopped,frame={addr="0x08002670",func="??",args=[]},thread-id="1",stopped-threads="all"
797^done
(gdb)
798 info threads
&"info threads\n"
~"* 1 Remote target  0x08002670 in ?? ()\n"
798^done
(gdb)
799 monitor soft_reset_halt
&"monitor soft_reset_halt\n"
@"requesting target halt and executing a soft reset\n"
799^done
(gdb)
800 file C:\\Daten\\Projekte\\sw\\stm32-mf-chibios\\src\\build\\chibi-mf.elf
&"file C:\\\\Daten\\\\Projekte\\\\sw\\\\stm32-mf-chibios\\\\src\\\\build\\\\chibi-mf.elf\n"
800^done
(gdb)
801-stack-info-depth
801^done,depth="2"
(gdb)
802-stack-list-frames 0 2
802^done,stack=[frame={level="0",addr="0x08002670",func="ResetHandler",file="../externals/ChibiOS-RT/os/ports/GCC/ARMCMx/crt0.c",fullname="c:\\daten\\projekte\\sw\\stm32-mf-chibios\\externals\\chibios-rt\\os\\ports\\gcc\\armcmx\\crt0.c",line="255"},frame={level="1",addr="0xffffffff",func="??"}]
(gdb)
803-environment-directory
803^done,source-path="$cdir;$cwd"
(gdb)
804-data-list-changed-registers
804^done,changed-registers=["0","1","2","3","4","5","6","7","8","9","10","11","12","13","14","15","16","17","18","19","20","21","22","23","24","25"]
(gdb)
805-data-list-register-names
805^done,register-names=["r0","r1","r2","r3","r4","r5","r6","r7","r8","r9","r10","r11","r12","sp","lr","pc","f0","f1","f2","f3","f4","f5","f6","f7","fps","cpsr","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",""]
(gdb)
806 info sharedlibrary
806^done
(gdb)
807 tbreak main
&"tbreak main\n"
tbreak main
~"Temporary breakpoint 1 at 0x80120f2: file main.c, line 90.\n"
=breakpoint-created,bkpt={number="1",type="breakpoint",disp="del",enabled="y",addr="0x080120f2",func="main",file="main.c",fullname="c:\\\\daten\\\\projekte\\\\sw\\\\stm32-mf-chibios\\\\src\\\\main.c",line="90",times="0",original-location="main"}
807^done
808 jump ResetHandler
(gdb)
jump ResetHandler
&"jump ResetHandler\n"
~"Note: automatically using hardware breakpoints for read-only addresses.\n"
808^running
*running,thread-id="all"
(gdb)
=breakpoint-modified,bkpt={number="1",type="breakpoint",disp="del",enabled="y",addr="0x080120f2",func="main",file="main.c",fullname="c:\\\\daten\\\\projekte\\\\sw\\\\stm32-mf-chibios\\\\src\\\\main.c",line="90",times="1",original-location="main"}
~"\nTemporary breakpoint "
Temporary breakpoint ~"1, main () at main.c:90\n"
~"90\t  halInit();\n"
90     halInit();
*stopped,frame={addr="0x080120f2",func="main",args=[],file="main.c",fullname="c:\\daten\\projekte\\sw\\stm32-mf-chibios\\src\\main.c",line="90"},thread-id="1",stopped-threads="all"
=breakpoint-deleted,id="1"
(gdb)
809 info threads
&"info threads\n"
~"* 1 Remote target  main () at main.c:90\n"
809^done
(gdb)
810-stack-info-depth
810^done,depth="1"
(gdb)
811-stack-list-frames 0 1
811^done,stack=[frame={level="0",addr="0x080120f2",func="main",file="main.c",fullname="c:\\daten\\projekte\\sw\\stm32-mf-chibios\\src\\main.c",line="90"}]
(gdb)
812-data-list-changed-registers
812^done,changed-registers=["0","1","2","3","4","5","13","14","15"]
(gdb)
813 info sharedlibrary
813^done
(gdb)
814-data-disassemble -s 0x80120f2 -e 0x8012172 -- 1
814^done,asm_insns=[src_and_asm_line={line="90",file="main.c",line_asm_insn=[{address="0x080120f2",func-name="main",offset="2",inst="bl\t0x8009980 <halInit>"}]},src_and_asm_line={line="91",file="main.c",line_asm_insn=[{address="0x080120f6",func-name="main",offset="6",inst="bl\t0x80075f0 <chSysInit>"}]},src_and_asm_line={line="92",file="main.c",line_asm_insn=[]},src_and_asm_line={line="93",file="main.c",line_asm_insn=[{address="0x080120fa",func-name="main",offset="10",inst="movw\tr0, #5244\t; 0x147c"},{address="0x080120fe",func-name="main",offset="14",inst="movt\tr0, #8192\t; 0x2000"},{address="0x08012102",func-name="main",offset="18",inst="movw\tr1, #14348\t; 0x380c"},{address="0x08012106",func-name="main",offset="22",inst="movt\tr1, #8192\t; 0x2000"},{address="0x0801210a",func-name="main",offset="26",inst="bl\t0x8009a80 <extStart>"}]},src_and_asm_line={line="94",file="main.c",line_asm_insn=[]},src_and_asm_line={line="95",file="main.c",line_asm_insn=[{address="0x0801210e",func-name="main",offset="30",inst="bl\t0x8010920 <wf_init>"}]},src_and_asm_line={line="96",file="main.c",line_asm_insn=[{address="0x08012112",func-name="main",offset="34",inst="bl\t0x8010c70 <ha_init>"}]},src_and_asm_line={line="97",file="main.c",line_asm_insn=[{address="0x08012116",func-name="main",offset="38",inst="bl\t0x800f680 <sd_init>"}]},src_and_asm_line={line="98",file="main.c",line_asm_insn=[]},src_and_asm_line={line="99",file="main.c",line_asm_insn=[{address="0x0801211a",func-name="main",offset="42",inst="mov.w\tr0, #4"},{address="0x0801211e",func-name="main",offset="46",inst="bl\t0x8011510 <mod_uart_init>"}]},src_and_asm_line={line="100",file="main.c",line_asm_insn=[{address="0x08012122",func-name="main",offset="50",inst="mov.w\tr0, #2"},{address="0x08012126",func-name="main",offset="54",inst="bl\t0x8011e80 <mod_wavplayer_init>"}]},src_and_asm_line={line="101",file="main.c",line_asm_insn=[{address="0x0801212a",func-name="main",offset="58",inst="mov.w\tr0, #1"},{address="0x0801212e",func-name="main",offset="62",inst="bl\t0x8011220 <mod_rfm_init>"}]},src_and_asm_line={line="102",file="main.c",line_asm_insn=[{address="0x08012132",func-name="main",offset="66",inst="mov.w\tr0, #3"},{address="0x08012136",func-name="main",offset="70",inst="bl\t0x8012060 <mod_bell_init>"}]},src_and_asm_line={line="103",file="main.c",line_asm_insn=[]},src_and_asm_line={line="104",file="main.c",line_asm_insn=[]},src_and_asm_line={line="105",file="main.c",line_asm_insn=[]},src_and_asm_line={line="106",file="main.c",line_asm_insn=[{address="0x0801213a",func-name="main",offset="74",inst="mov.w\tr0, #500\t; 0x1f4"},{address="0x0801213e",func-name="main",offset="78",inst="bl\t0x8008380 <chThdSleep>"}]},src_and_asm_line={line="107",file="main.c",line_asm_insn=[{address="0x08012142",func-name="main",offset="82",inst="mov.w\tr3, #3072\t; 0xc00"},{address="0x08012146",func-name="main",offset="86",inst="movt\tr3, #16386\t; 0x4002"},{address="0x0801214a",func-name="main",offset="90",inst="mov.w\tr2, #3072\t; 0xc00"},{address="0x0801214e",func-name="main",offset="94",inst="movt\tr2, #16386\t; 0x4002"},{address="0x08012152",func-name="main",offset="98",inst="ldr\tr2, [r2, #20]"},{address="0x08012154",func-name="main",offset="100",inst="eor.w\tr2, r2, #32768\t; 0x8000"},{address="0x08012158",func-name="main",offset="104",inst="str\tr2, [r3, #20]"}]},src_and_asm_line={line="108",file="main.c",line_asm_insn=[{address="0x0801215a",func-name="main",offset="106",inst="b.n\t0x801213a <main+74>"}]}]
(gdb)
815-data-disassemble -s 0x801215a -e 0x80121e2 -- 1
815^done,asm_insns=[src_and_asm_line={line="108",file="main.c",line_asm_insn=[{address="0x0801215a",func-name="main",offset="106",inst="b.n\t0x801213a <main+74>"}]}]
(gdb)
816-data-disassemble -s 0x801215a -e 0x80121e2 -- 0
816^done,asm_insns=[{address="0x0801215a",func-name="main",offset="106",inst="b.n\t0x801213a <main+74>"},{address="0x0801215c",inst="nop.w"},{address="0x08012160",inst="cmp\tr2, #34\t; 0x22"},{address="0x08012162",inst="subs\tr4, #58\t; 0x3a"},{address="0x08012164",inst="subs\tr7, #62\t; 0x3e"},{address="0x08012166",inst="ldrb\tr4, [r7, #29]"},{address="0x08012168",inst="movs\tr0, r0"},{address="0x0801216a",inst="movs\tr0, r0"},{address="0x0801216c",inst="cmp\tr4, #43\t; 0x2b"},{address="0x0801216e",inst="subs\tr5, #59\t; 0x3b"},{address="0x08012170",inst="ldrb\tr3, [r3, r5]"},{address="0x08012172",inst="movs\tr0, r0"},{address="0x08012174",inst="mcr2\t13, 7, r4, cr11, cr0, {4}"},{address="0x08012178",inst="add\tr3, r10"},{address="0x0801217a",inst="strh\tr7, [r1, r5]"},{address="0x0801217c",inst="cmp\tr6, #53\t; 0x35"},{address="0x0801217e",inst="movs\tr0, r6"},{address="0x08012180",inst="ldr\tr7, [pc, #312]\t; (0x80122bc)"},{address="0x08012182",inst="ldr\tr6, [pc, #128]\t; (0x8012204)"},{address="0x08012184",inst="ldr\tr5, [pc, #260]\t; (0x801228c)"},{address="0x08012186",inst="movs\tr0, #69\t; 0x45"},{address="0x08012188",inst="movs\tr0, #32"},{address="0x0801218a",inst="mov\tr0, r4"},{address="0x0801218c",inst="strb\tr1, [r0, r1]"},{address="0x0801218e",inst="adds\tr2, #51\t; 0x33"},{address="0x08012190",inst="movs\tr0, #32"},{address="0x08012192",inst="movs\tr0, r4"},{address="0x08012194",inst="ldr\tr7, [pc, #312]\t; (0x80122d0)"},{address="0x08012196",inst="ldr\tr6, [pc, #128]\t; (0x8012218)"},{address="0x08012198",inst="ldr\tr5, [pc, #260]\t; (0x80122a0)"},{address="0x0801219a",inst="movs\tr0, #69\t; 0x45"},{address="0x0801219c",inst="movs\tr0, #32"},{address="0x0801219e",inst="mov\tr0, r4"},{address="0x080121a0",inst="strb\tr1, [r0, r1]"},{address="0x080121a2",inst="movs\tr0, #32"},{address="0x080121a4",inst="movs\tr0, #32"},{address="0x080121a6",inst="movs\tr0, r4"},{address="0x080121a8",inst="movs\tr0, r0"},{address="0x080121aa",inst="movs\tr0, r0"},{address="0x080121ac",inst="movs\tr0, r0"},{address="0x080121ae",inst="movs\tr0, r0"},{address="0x080121b0",inst="str\tr1, [r5, #68]\t; 0x44"},{address="0x080121b2",inst="str\tr4, [r5, #84]\t; 0x54"},{address="0x080121b4",inst="movs\tr0, r0"},{address="0x080121b6",inst="movs\tr0, r0"},{address="0x080121b8",inst="movs\tr0, r0"},{address="0x080121ba",inst="movs\tr0, r0"},{address="0x080121bc",inst="movs\tr0, r0"},{address="0x080121be",inst="movs\tr0, r0"},{address="0x080121c0",inst="ldrsb\tr3, [r2, r1]"},{address="0x080121c2",inst="adds\tr1, #35\t; 0x23"},{address="0x080121c4",inst="movs\tr0, r0"},{address="0x080121c6",inst="movs\tr0, r0"},{address="0x080121c8",inst="ldrsb\tr3, [r2, r1]"},{address="0x080121ca",inst="adds\tr2, #35\t; 0x23"},{address="0x080121cc",inst="movs\tr0, r0"},{address="0x080121ce",inst="movs\tr0, r0"},{address="0x080121d0",inst="ldrsb\tr3, [r2, r1]"},{address="0x080121d2",inst="adds\tr3, #35\t; 0x23"},{address="0x080121d4",inst="movs\tr0, r0"},{address="0x080121d6",inst="movs\tr0, r0"},{address="0x080121d8",inst="ldrsb\tr3, [r2, r1]"},{address="0x080121da",inst="adds\tr4, #35\t; 0x23"},{address="0x080121dc",inst="movs\tr0, r0"},{address="0x080121de",inst="movs\tr0, r0"},{address="0x080121e0",inst="ldrsb\tr3, [r2, r1]"}]
(gdb)
OpenOCD is startet this way:
openocd -f scripts\board\stm32f4discovery.cfg
and says:
Open On-Chip Debugger 0.7.0-dev-gcb69d06 (2012-10-07-15:02)
Licensed under GNU GPL v2
For bug reports, read
   http://openocd.sourceforge.net/doc/doxygen/bugs.html
adapter speed: 1000 kHz
srst_only separate srst_nogate srst_open_drain
Info : clock speed 1000 kHz
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : accepting 'gdb' connection from 3333
Info : stm32f4x errata detected - fixing incorrect MCU_IDCODE
Info : device id = 0x10006413
Info : flash size = 1024kbytes
Warn : acknowledgment received, but no packet pending
undefined debug reason 6 - target needs reset
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 1.977539s (41.592 KiB/s)
Info : dropped 'gdb' connection
Info : Padding image section 0 with 8 bytes
Info : halted: PC: 0x0801213e
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 2.018554s (40.747 KiB/s)
Warn : negative acknowledgment, but no packet pending
Error: address + size wrapped(0xfffffffe, 0x00000004)
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 2.014649s (40.826 KiB/s)
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 2.296875s (35.810 KiB/s)
Warn : keep_alive() was not invoked in the 1000ms timelimit. GDB alive packet not sent! (2357). Workaround: increase "set remotetimeout" in GDB
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 1.873047s (43.912 KiB/s)
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 1.886719s (43.594 KiB/s)
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 1.890625s (43.504 KiB/s)
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 1.855469s (44.328 KiB/s)
Error: address + size wrapped(0xffffffff, 0x00000004)
Warn : WARNING! The target is already running. All changes GDB did to registers will be discarded! Waiting for target to halt.
wrote 84224 bytes from file ../stm32-mf-chibios/src/build/chibi-mf.elf in 1.934570s (42.516 KiB/s)
I changed line 54 of ${OPENOCDROOT}/scripts/target/stm32f4x.cfg to
target create $_TARGETNAME cortex_m3 -endian $_ENDIAN -chain-position $_TARGETNAME -rtos auto
Thank you for helping me.
mabl
Post by mabl »
Hi feanor,
the stm32 is an stlink target and it has it's own target in openocd:
cat ~/bin/oocd/share/openocd/scripts/board/stm32f4discovery.cfg
# This is an STM32F4 discovery board with a single STM32F407VGT6 chip.
# http://www.st.com/internet/evalboard/product/252419.jsp
source [find interface/stlink-v2.cfg]
source [find target/stm32f4x_stlink.cfg]
# use hardware reset, connect under reset
reset_config srst_only srst_nogate
So you will have to modify stm32f4x_stlink.cfg not stm32f4x.cfg.
Best,
MaBl
feanor
Post by feanor »
Hi mabl,
thanks for the hint. Now openocd tells me
Auto-detected RTOS: ChibiOS
Info : Successfully loaded memory map of ChibiOS/RT target running version 2.5.1
Error: ChibiOS registry integrity check failed, double linked list violation
Info : Only showing current execution because of a broken ChibiOS thread registry.
mabl
Post by mabl »
Hi feanor,
Basically it is like the error said - oocd thinks your thread registry is borken. But i think this is caused by the error message before.
Are you sure your way of installing oocd is correct? I saw this error also in your log before - and there rtos support did not run.
